![]() | Home > Maintenance & Modifications > Not another FBH question... |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
That's the one which I have for my 2010 YM TDV6 and it works fine.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
This is what I have on my tdv8,,, I don't know if the difference between the 2 is that one system gives interior heat and the other just fires up the FBH to pre warm the engine coolant,,,, lm sure I've read something on those lines.
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
The timed climate works great, so I'll give the fob another go over the weekend.
So I've been out and had another play this morning and I can't get the fob to pair with the receiver no matter which way I try. Fuse out wait put it back in and hold off button etc.
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
Hi, I have the T91R module fitted to mine, but after reading many posts on the forums I went for the T90 remote ?, The one with on and off on the buttons, and it paired up very easily with the module, and I have my CCF set the same as you. But I would have though having a T91R module and a T91R remote, they would have talked to each other, the remote must have been made to talk to something. |
