Home > Technical > Electronic handbrake fault (not engaging)
MallorcaNick
Spain 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi all,
I've just spent about 2 hours on here looking for a solution to my electronic handbrake issue, but couldn't find anything to answer my problem.
Firstly, there's no screaming noise and it isn't locked "on".
It's simple - if I try and turn it on, it just shows a red error on the dash and a few beeps. I've read the "use it or lose it" comments and I definitely haven't used it enough (at all!). It just doesn't work.
So, my question is: is this a difficult or complicated fix? As it's a RR, I imagine it's not simple but I was hoping to get some advice from you guys as you've saved me fortunes in the past. I've got my MOT here in Spain soon so might need it fixed in advance, although I'm not sure if they'll even look for that here.
Thanks in advance.......
Post #618048 Tue Oct 12 2021 11:52am
MallorcaNick
Can't anyone help please???
Post #618444 Wed Oct 27 2021 9:37am
It probably needs to have the codes read to make sure there's no pointers there to start with. Otherwise, if it's not applying at all, it's either the EPB module itself or switch/wiring to it. I wonder if a fully seized actuator on one wheel would prevent the whole thing from working or whether it's designed to allow the other one still to work.
Check the codes
Take the rear brakes off and have a look at the brakes and see if they're seized.
Other than that, not much to suggest. 2012 SDV6 - it's missing a couple of cylinders
Post #618455 Wed Oct 27 2021 3:50pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
I can’t remeber the symptoms, but I never used my park brake, had an issue and removed the drums.
The friction material had separated from the shoes, took ages to clean out, new shoes and all was fine.
Post #618462 Wed Oct 27 2021 7:19pm
MallorcaNick
Check the codes
The mechanic told me last week that it's the EPB module that needs changing. Is than an expensive and difficult fix???
Post #621442 Mon Jan 31 2022 3:59pm
Advanced Factors
Site Sponsor
For AA000001 (2010) onwards the parking brake module is LR072318
We sell them for £609.56 + tax
For the earlier handbrake module there is a gear repair kit. I'm not sure if there is one for the version you need. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #621443 Mon Jan 31 2022 4:34pm
