Home > General (L494) > SDV6 Engine issues ever resolved??
Lawsol
I’m considering purchasing a face lift RRS 2018 onwards and wondered if the v6 diesel crank issues ever got resolved throughout MYs?
Thanks
Post #617531 Tue Sep 21 2021 3:39pm
If you mean the small number of snapped crankshafts, then no, the crankshaft wasn't changed over the years.
It's worth remembering that, although a horrible thing to have happen, when one thinks of how many 3.0 V6 diesels that LR sold (across the Discovery, RRS and FFRR), the number of failures is thankfully pretty small and the risk likewise.
If it's a big worry but you still want a RRS, how about the V8 diesel? Lots of lovely grunt and still decent fuel economy on a run. 2012 SDV6 - it's missing a couple of cylinders
Post #617533 Tue Sep 21 2021 4:04pm
Lawsol
Thanks for the response.
Unfortunately due to the car allowance scheme I have through work, I need to keep to under 210g/km and 3.0 or under for engine size. So it’s between the sdv6 and p400e
Post #617534 Tue Sep 21 2021 4:11pm
Chips
My 2018 snapped it's crank . I have just bought extended warranty in case it happens again . Before buying the warranty I enquired as to whether it would cover a crank failure as it's a know manufacturer's defect with a bulletin issued . The warranty company said it would as all replacement engines have an upgraded crank and thus it wouldn't be a manufacturer's defect if it went again . Whether that is true or not I don't know but either way at least I won't have to pay for repair . MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #617605 Wed Sep 22 2021 6:59pm
vegnomeat
You may say it's a small number of snapped crankshafts. However, name me another engine which is known for snapped crankshafts, that has been a continuing fault for over 12 years? I'll pull up a chair as I know it's going to be a long wait.
Post #618049 Tue Oct 12 2021 12:09pm
Dave-t
Most manufacturers have their own problems, for instance Porsche had bore score on 997 and most others will have some problem. If you don’t want one then don’t buy one…..simple really Joined the X5 45e club
1994 Defender 90 300 tdi
Post #618055 Tue Oct 12 2021 4:38pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Not to mention the 997 infamous IMS bearing that was modelled on a washing machine bearing - only worse (don't ask me how I know)!
Post #618056 Tue Oct 12 2021 4:56pm
the issue with the cheese cranks is that JLR wash their hands off the problem, and most people affected then end up with massive repair bills.
had JLR stepped up and just replaced the engines, then it wouldn't have been such a major issue. --
Post #618058 Tue Oct 12 2021 5:18pm
vegnomeat
I have purchased one, a late 2017 RRS. I don’t see where you get off on minimising the issue. I’m still sat on this chair waiting to find out about other engines that the crank snaps on.
Post #618063 Tue Oct 12 2021 7:46pm
At least if you're sat on that chair you won't be driving your RRS and risking the crank snapping. Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #618070 Tue Oct 12 2021 10:17pm
Isn't the issue that it's not their engine - it's a Ford / PSA engine adapted for Land Rover's use and produced in Ford's factory. I guess they could have paid Ford to redesign the crank and then take the future breakages of the old version on the chin, but the question is - how many have actually failed?
It has been suggested hereabouts by a couple of LR indies that the crank failures are usually associated with low oil levels. Not helped by the engine not giving a low oil warning, of course. 2012 SDV6 - it's missing a couple of cylinders
Post #618071 Tue Oct 12 2021 10:21pm
Turdmon
Very Happy Very Happy
Post #618119 Fri Oct 15 2021 6:45am
Didn't JLR take over the production of these engines in 2012? --
Post #618120 Fri Oct 15 2021 7:46am
OvalAutos
Where to start......
https://www.drivingline.com/articles/5-fat...-fix-them/
https://www.alfabb.com/threads/broken-crankshaft.177340/
https://www.econologie.com/forums/econolog...9-660.html
https://www.subaruforester.org/threads/200...ft.120394/
A lovely example by Ford.
There is no such thing as the perfect engine by any manufacturer. Engines are literally trying to tear themselves apart with the forces exerted on them with each rotation. Joe
Post #618121 Fri Oct 15 2021 7:48am
https://www.4x4community.co.za/forum/showt...re-Reports --
Post #618122 Fri Oct 15 2021 7:59am
