Home > General (L494) > SDV6 Engine issues ever resolved??
Harveyp500
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Got to admit I do not know much about the crank failure issue but i have along with my daughter had up till now 4 of the 3.0 litre diesels and, as yet, touch wood, had no engine or crank issues what so ever.
That said, and not sure if it makes any difference with this problem, we do cover around 2k miles a month each, drive them fast, keeping them within the speed limit-ish of course and service them as soon as they ask for it with a few extra oil changes thrown in just for good measure at our local indy garage. 2023 D350 FIRST EDITION, SANTORINI WITH CLOUD/EBONY
2024 DEFENDER D250 110 HSE APACHE
2009 2.7 TDV6 HSE SANTORINI BLACK
GONE
2020 RRS P400e AUTOGRAPHY
2018 3.0 SDV6 AUTOBIOGRAPHY, CARPATHIAN GREY, SANTORINI PAN ROOF, IVORY INTERIOR. Now gone but will be missed, Cracking motor.
2015 3.0 SDv6 HSE DYNAMIC CORRIS
2014 3.0 SDV6 HSE FUJI WHITE CONTRAST SANTORINI PAN ROOF.
Evoque 2.2 d Pure Tech Auto
P38 4.0 HSE
Disco 2.5 d XS
Post #618174 Mon Oct 18 2021 4:30pm
Chips
Just read this on another forum, I wonder if there is any truth in it as it seems quite unbelievable if there is !
The reason why your crank split is that some idiot at the factory over stressed it, when straightening it after it had been ground. The culprit was eventually discovered and sacked on the spot!
He had been using 2 & 1/2 times more pressure that he was told to, thinking he was doing LR a favour, rather than binning cranks that needed more than the maximum force recommended to straighten them. He’d been doing it for 6 years. MY24 Dynamic SE,MY21 HSE Silver, MY20 SQ7, MY 18 RRS HSE Dynamic , MY 16 RRS Autobiography now gone & MY 2005 Discovery 3 HSE that I will be buried in !
Post #625012 Sat Jun 25 2022 8:12pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Mmm interesting… I suspect LR would never admit to this but if it was true they should know what crank shafts went into which vehicle and should have recalled them all…..
Post #625013 Sat Jun 25 2022 9:46pm
And when did this happen? And could you please post a link to the other forum/post? thanks
Because for the first time ever (that I know of), a recent D5 ate its crank: https://www.facebook.com/groups/784537394985099/user/745885060
Quote:
After some engine advice.... I currently have a Discovery 5 with the SDV6 engine which has had the infamous crank failure, only 31K miles and was while in The Netherlands on a highway (we are from the UK).
So we are looking to swap to a RRS, most likely a 2018+, and want to avoid the crank issue. What would you recommend as the best engine? Wondering about the 3.0 V6 Petrol, maybe the P400e, what about the 4.4 V8 Diesel, does it have the same issue? I know not all the SDV6's have the issue, but not willing to go down that route again, being stuck at the side of a highway with the kids when it is a known issue not covered by extended warranty was not fun.
...my Discovery 5 was approved used, had full main dealer service and was on an Extended LR Warranty. Dealer service manager has confirmed that the extended warranty will not cover the engine failure due to crank issue as it is a known issue, however LR will usually foot the bill but on a case by case basis based on service history, having an extended LR warranty and brand loyalty....
Post #625022 Sun Jun 26 2022 10:44am
jimbg
Total rubbish I would say, they are still failing on the Disco5
https://disco5.co.uk/forum/thread3383.html 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #625030 Sun Jun 26 2022 3:57pm
