![]() | Home > General > Towbar |
Old grump&Bluesport Member Since: 31 Jul 2021 Location: Irvine Ayrshire Posts: 15 ![]() ![]() ![]() |
Good day all, hope all well.
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 ![]() ![]() ![]() |
I use the factory hook admittedly I only have a two berth van @ about 1300kg all up. Check the condition of your receiver in the chassis for corrosion some fixed bars still use this, mine still had the red plastic cover in and when I got a s/hand hook and put it in there was no movement.
Tow Trust. |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 68 ![]() ![]() ![]() |
I'm just using the removable standard one. But with the security plate.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
There's a recall on the tow hitch receiver for RRSs - check if yours has been checked. Apparently they can wear with use.
I have Tow Trust's removeable tow bar. They no longer sell it as I think the supplier of the mechanism stopped making them. Anyway, I find it tows better with the Tow Trust device than the LR removable one. I think the LR ball height is a bit low on the RRS and with a twin axle horse trailer, it's not quite as stable as the Tow Trust ball. Same trailer, same vehicle, different tow bars/balls, so it must be the design of the bar and the / or the ball height. 2012 SDV6 - it's missing a couple of cylinders
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Marketing strap line they never used maybe " Your balls hang lower with genuine parts" 2012 SDV6 HSE (technically its hers)
nigethecat Member Since: 22 Sep 2016 Location: Aberdeenshire Posts: 115 ![]() ![]() ![]() |
Just bought a new Tow Trust TL1 for my Disco, less than £200 new from a supplier in Warrington, delivered next day (cheaper than Tow Trust Direct!). D3 LHD - great car !
