Home > General > Is the Air suspension fault an MOT fail? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I don't think they function the suspension system as part of the MOT so can't see it being a problem,, if only normal height is available why should it be an issue,, thats what the suspension is set at during normal road use anyway. 2010 RRS, TDV8
Sun Aug 01 2021 4:40pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
If there's a warning light on the dash then I think you'll struggle. 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 01 2021 6:10pm |
RRSMARC Member Since: 20 Aug 2018 Location: Leicestershire Posts: 3 |
I was hoping that because normal height is what you use to drive that it would be ok but on the other hand I thought any warning light was an automatic fail.
Sun Aug 01 2021 6:39pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 220 |
Mine had an advisory a few years back , just said that the instrument panel indicates a suspension fault didn't fail it, everything was working normally . |
Sun Aug 01 2021 7:01pm |
I can confirm that the suspension light is an advisory and not a fail. |
Mon Aug 02 2021 9:02am |
That's good news. I guess the fact that the suspension won't raise to off road height isn't relevant to an MOT. 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 02 2021 11:17am |
