Home > General > Is the Air suspension fault an MOT fail?
RRSMARC
Hi All,
I have gone to drive my car today and my compressor stayed on longer than normal and then just cut out and got the yellow light with normal height only.
Plugged it in and got C1A20-64 code so it could be the compressor.
I just want to know if it is a straight MoT fail as my Mot is booked for tomorrow? Sad
Post #616276 Sun Aug 01 2021 3:36pm
gogsy1956
I don't think they function the suspension system as part of the MOT so can't see it being a problem,, if only normal height is available why should it be an issue,, thats what the suspension is set at during normal road use anyway. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #616277 Sun Aug 01 2021 5:40pm
If there's a warning light on the dash then I think you'll struggle. 2012 SDV6 - it's missing a couple of cylinders
Post #616278 Sun Aug 01 2021 7:10pm
RRSMARC
I was hoping that because normal height is what you use to drive that it would be ok but on the other hand I thought any warning light was an automatic fail.
Usually I would Mot the car 3-4 weeks in advance just incase it needed any work doing but as the wife wanted to go away over the last couple of weeks I’ve only got a few days left.
So looks like it might be an expensive time at the garage rather than attempt a rebuild it myself.
Post #616281 Sun Aug 01 2021 7:39pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Mine had an advisory a few years back , just said that the instrument panel indicates a suspension fault didn't fail it, everything was working normally .
Post #616282 Sun Aug 01 2021 8:01pm
RRSMARC
I can confirm that the suspension light is an advisory and not a fail.
Post #616289 Mon Aug 02 2021 10:02am
That's good news. I guess the fact that the suspension won't raise to off road height isn't relevant to an MOT. 2012 SDV6 - it's missing a couple of cylinders
Post #616292 Mon Aug 02 2021 12:17pm
