Home > In Car Electronics > phone wiring |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
No the wiring won’t be there.
Thu Jun 03 2021 12:02pm |
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 73 |
It’s says it’s an HSE has Harmon carmon sound sat nav under passenger seat and an amp under the drivers seat |
Thu Jun 03 2021 5:35pm |
So if I fit a d4 Bluetooth unit where and what most wire do I need to connect it too |
Tue Jun 15 2021 7:37am |
You buy a most cable with 3 connectors on it.
Tue Jun 15 2021 7:46am |
So the head unit or the amp under the seat if I mount it under the seat could I pick up the power from the amp too or would it interfere with the signals
Tue Jun 15 2021 9:27am |
yes you could connect to the most at the amp.
Tue Jun 15 2021 9:59am |
Thanks |
Tue Jun 15 2021 11:18am |
So turns out not all D4 units have the same fibre optical socket and I have got one that hasn’t |
Wed Jun 16 2021 6:57am |
you have one with no fibre socket at all ?
Wed Jun 16 2021 8:25am |
So just to confirm pos red wire on pin 31
Thu Jun 17 2021 11:22pm |
I don't know off hand.
Fri Jun 18 2021 8:18am |
Well plugged in but car still thinks it’s got no phone connected |
Fri Jun 18 2021 7:29pm |
Have you changed the CCF file to say it has a phone fitted ? |
Fri Jun 18 2021 8:06pm |
I think so |
Fri Jun 18 2021 8:33pm |
