Home > In Car Electronics > phone wiring
jk3528
phone wiring
i have a 2006 which says it has no phone fitted but will the wiring be there to fit one?
i have looked in the rear right panel but no spare wires in there could they be somewhere else?
Post #614252 Thu Jun 03 2021 12:58pm
No the wiring won’t be there.
Ppl sometimes fit D4 BT units.
Which require 2 wires and an optical bus connection.
And enabling with gap iid
On the assumption you have a high spec model with amp under seat and/or lcd display
https://www.disco3.co.uk/forum/d4-bluetoot...53302.html
If you don’t get your nav working and want a rear cam look at this.
https://www.rrsport.co.uk/forum/topic55655.html
Post #614253 Thu Jun 03 2021 1:02pm
jk3528
It’s says it’s an HSE has Harmon carmon sound sat nav under passenger seat and an amp under the drivers seat
Post #614272 Thu Jun 03 2021 6:35pm
jk3528
So if I fit a d4 Bluetooth unit where and what most wire do I need to connect it too
Post #614775 Tue Jun 15 2021 8:37am
You buy a most cable with 3 connectors on it.
A bit like this:
https://www.ebay.co.uk/itm/153594620806?ha...SwcHVdSxZO
https://www.ebay.co.uk/itm/402456516433?_t...%3A2047675
And then connect it, where there is already a most port.
e.g by the headunit or in the rear boot (right)
Post #614776 Tue Jun 15 2021 8:46am
jk3528
So the head unit or the amp under the seat if I mount it under the seat could I pick up the power from the amp too or would it interfere with the signals
Post #614778 Tue Jun 15 2021 10:27am
yes you could connect to the most at the amp.
I've not heard anyone choose that option. (maybe because there is no physical space, or its likely to be kicked or nothing to fix it to.
I would have to check if there was a suitable power connection at the amp. (even if there wasn't, it not difficult to run a wire from the dash)
People usually put them behind the dash, to one side of the headunit I believe
Post #614779 Tue Jun 15 2021 10:59am
jk3528
Thanks
Post #614780 Tue Jun 15 2021 12:18pm
jk3528
So turns out not all D4 units have the same fibre optical socket and I have got one that hasn’t
Post #614804 Wed Jun 16 2021 7:57am
you have one with no fibre socket at all ?
I nearly fell into a similar trap.
It is confussing.
Have a good read here. I believe its the big retangular unit that is needed.
And exact part number.
Post #614807 Wed Jun 16 2021 9:25am
jk3528
So just to confirm pos red wire on pin 31
Black negative on pin 15
Post #614879 Fri Jun 18 2021 12:22am
I don't know off hand.
If that is what the link says, and assuming the connector only has 2 rows of pins
Post #614888 Fri Jun 18 2021 9:18am
jk3528
Well plugged in but car still thinks it’s got no phone connected
Post #614912 Fri Jun 18 2021 8:29pm
Have you changed the CCF file to say it has a phone fitted ?
Post #614915 Fri Jun 18 2021 9:06pm
jk3528
I think so
Post #614916 Fri Jun 18 2021 9:33pm
