![]() | Home > Maintenance & Modifications > How much oil just to take back to full level. |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 591 ![]() ![]() |
Third of a litre should do it no more |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
Its approx 1L between minimum + maximum levels on the display, 125ml(ish) per division |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
First point: Believe Disco Mickey he knows what he’s talking about.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Agreed. I wouldn't try to top up on one division. Too easy to overfill it. 2012 SDV6 - it's missing a couple of cylinders
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1194 ![]() ![]() ![]() |
^ yep, only add oil when the car tells you to, I've seen what happens to a Disco4 with oil overfill and it wasn't pretty nor cheap to fix --
Sparkey Member Since: 03 Feb 2021 Location: Yorkshire Posts: 24 ![]() ![]() ![]() |
Thanks for the replies. |
Mike, is it 1L on all models, or is this specific to the SDV6? I tried but didn't find a reference in the workshop manual. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
At what point will the vehicle warn to add oil?
The car doesn't warn you when the oil is low |
Seepee3o Member Since: 05 Dec 2020 Location: Hogsthorpe Posts: 12 ![]() ![]() ![]() |
At halfway, I would add oil, but do it in 125ml increments and check after each addition.
