Home > Maintenance & Modifications > How much oil just to take back to full level.
Sparkey
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Firenze Red
Checked my 2012 RRS 3.0 SDV6 on Friday, and it has just dropped to the first level down on the electronic gauge.
How much would you add to take it back upto the full level but not overfill?
I've bought a Litre of Castrol Edge Pro 5w 30 C1 grade.
Post #612020 Sun Mar 28 2021 11:42am
Red Arrow
Third of a litre should do it no more Thumbs Up
Post #612025 Sun Mar 28 2021 1:14pm
Disco_Mikey
Its approx 1L between minimum + maximum levels on the display, 125ml(ish) per division Thumbs Up
Post #612026 Sun Mar 28 2021 1:18pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
First point: Believe Disco Mickey he knows what he’s talking about.
Second point: Take another reading and if says “OK” then don’t add any oil.
Overfilling is bad. One div down is not.
Post #612033 Sun Mar 28 2021 2:31pm
Agreed. I wouldn't try to top up on one division. Too easy to overfill it. 2012 SDV6 - it's missing a couple of cylinders
Post #612041 Sun Mar 28 2021 6:57pm
^ yep, only add oil when the car tells you to, I've seen what happens to a Disco4 with oil overfill and it wasn't pretty nor cheap to fix --
Post #612052 Mon Mar 29 2021 6:31am
Sparkey
Thanks for the replies.
Post #612053 Mon Mar 29 2021 6:33am
Mike, is it 1L on all models, or is this specific to the SDV6?
I tried but didn't find a reference in the workshop manual. --
Post #612054 Mon Mar 29 2021 6:41am
Sparkey
At what point will the vehicle warn to add oil?
Half way between min and max, or when it gets to minimum?
Post #612058 Mon Mar 29 2021 8:38am
Disco_Mikey
The car doesn't warn you when the oil is low Shocked
Post #612060 Mon Mar 29 2021 10:19am
Seepee3o
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Shocked Mine is on halfway Mark and I was wondering whether to add oil or not. Not happy that it won’t warn me to add so will attempt to add 125ml per division (less 125ml to be safe!) 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it
Post #612648 Wed Apr 14 2021 7:11pm
At halfway, I would add oil, but do it in 125ml increments and check after each addition.
btw, where is the oil level sensor located? I parked on a slight incline (engine facing down), and I saw a 2-level drop in oil, but at home, with the barest of incline (also engine facing down), only one level.
should I not bother topping up with only one level down? --
Post #619243 Wed Nov 17 2021 4:03pm
