![]() | Home > General > Warped brake disks |
Yes,
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 247 ![]() ![]() |
They are a bit worn so I might as well replace them. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Not necessarily?
Do you get a "pulsing" sensation through the brake pedal at all as this can be a sign of warped discs as well, especially if they are bad.
Isn’t there a place in Amesbury that will skim the discs whilst fitted to the car. 2006 2.7 TDV6 HSE in Cairns Blue. |
Just measured the disks and they definitely need replacing.
