Home > Technical > Tailgate
Page 1 of 4 1234>
Tailgate
Have any other owners found that their tailgate will only open just below head high? Will a basic clean work or can I add some oil/wd40? I have nearly knocked myself out several times so far! Crying or Very sad 2005 Zambezi TDV6 - Gone but not forgotten
Post #6082 Mon Nov 28 2005 1:09pm
Nope - I'm 6'4" and it opens a couple of inches over my head... did it used to open higher?
Post #6086 Mon Nov 28 2005 1:12pm
Yes and it still will if I push it up. 2005 Zambezi TDV6 - Gone but not forgotten
Post #6088 Mon Nov 28 2005 1:13pm
I've been meaning to mention this for a while. My tailgate stutts dont appear to be lifting the tailgate full up any more. So its as you say, do they need a special clean or some lubricant or perhaps a visit to the dealer for attention Question
Post #6089 Mon Nov 28 2005 1:15pm
Good to hear it's not just me. I didn't want to try anything unless......... 2005 Zambezi TDV6 - Gone but not forgotten
Post #6091 Mon Nov 28 2005 1:17pm
d3matt
United Kingdom 2005 Range Rover Sport TDV6 SE Bonatti Grey
Yes, mine is doing the same. The struts hardly lift the tailgate at all now. Matt
RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance!
Post #6117 Mon Nov 28 2005 2:43pm
WD40? 2005 Zambezi TDV6 - Gone but not forgotten
Post #6118 Mon Nov 28 2005 2:44pm
Don't think I've ever noticed but are the struts hydraulic? Could be poorly fitting hydraulics... my dad had that issue on a Peugeot once. There was a service bulletin out for their replacement... just checked GTR, no mention there though.
Post #6119 Mon Nov 28 2005 2:52pm
d3matt
WD40 hasn't made any difference. Even with a good flick, the bood lid only goes up to my neck. You have to give a push to get it to rise to just above head height, but then you could still bang your head. It looks like the gas struts have lost their power (sure not after only six months) or aren't big enough. Matt
Post #6120 Mon Nov 28 2005 3:00pm
Mine are getting worse only after 2 months Crying or Very sad
Post #6124 Mon Nov 28 2005 3:12pm
MDP and mpwox11
When did you take delivery of your RRS - it might be a batch problem! I got mine 1/6/05 2005 Zambezi TDV6 - Gone but not forgotten
Post #6125 Mon Nov 28 2005 3:17pm
16/sept/2005
Post #6127 Mon Nov 28 2005 3:20pm
Which was the day after mine... I'll look forward to my tailgate not opening properly by the weekend then Wink
Post #6129 Mon Nov 28 2005 3:27pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Mine has also show this tendency recently.
Let's not forget though that unassisted hydraulics such as these (i.e. not powered by a motor) will run less efficient in colder weather, and it's only since the cold snap mine has done this.
Also, don't forget that if your car is in access height the lifted taligate height will also be compromised. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #6132 Mon Nov 28 2005 3:42pm
scorpio
United Kingdom 2005 Range Rover Sport TDV6 SE Rimini Red
re tailgate
happened to me today, only raised the top part, turned round and whack, straight into to locking unit. Think it is the cold weather causing oil or gas to thicken inside the ram.
Post #6209 Mon Nov 28 2005 7:45pm
Page 1 of 4 1234>
