![]() | Home > Technical > Tailgate |
I figured it out - the extra weight of the sticker on the tailgate is causing the problem. ![]() 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
Quasimoto Member Since: 27 Jul 2005 Location: Middleburg, VA Posts: 34 ![]() ![]() |
Martin -- I've been noticing the same squeek/rattle in the past week also. I'm hoping it's due to a small gap that's developed somewhere due to the cold weather (and not a bigger problem!). When I go over speed bumps, it sounds as if the the rear tailgate's not quite closed all the way, but nothing on the display. The sound was so distinct I got out and gave it a good slam. Over the next bump...same thing. I'll be interested to hear what your dealer has to say... -QM |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
On mine there is two rubber stops on each part of the tailgate, so you can do the same for the lower part as you did for the glass part... L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
SORRY RRUK - I had'nt noticed this, I did the top glass ones OK , but then looked at the main tailgate rubbers , gave them a twist & thought they didnt screw out like the others, but now, after a second look I have discovered as you quite rightly point out, they do screw out enabling adjustment. So I will play around with these to see if I can cure the rattle THANKS MDP ![]() ![]() ![]() ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
![]() ![]() 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
VA ..... |
of course like mine, if you have had the rear number plate light replaced, you will still have the broken part of the old light fitting rattling about inside the top tailgate cos the monkey who fixed it was not thorough enough to fish out the debris.... |
kam100 Member Since: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4771 ![]() ![]() |
damn.. i have had this replaced on mine too!
It would appear that these rubber srew/stops do adjust. Having played around with them I think I have cured the annoying rattle. |
Another result for the RRSport team! 2005 Zambezi TDV6 - Gone but not forgotten 2009 Alaska TDV8 - Gone and much missed. ![]() WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
sorry for diggin up but i have this problem too.
