Home > General > What Size Wheels/Tyres |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
They do look low profile and wide too.
Sat Mar 13 2021 6:23pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
275/40/20 is a correct size although on a 2007 2.7 it might be that you shouldn't have 20 inch rims fitted anyway. Early 2.7 weren't designed to have rims over 19 as the steering rack needed a damper. The V8 petrol and diesel had the damped rack. Not sure whether a 2007 2.7 would have it. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 13 2021 6:42pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Had 22s with 285/35 tyres on my Disco 3 MY2005 which mechanically was identical to L320.
Sat Mar 13 2021 7:06pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
So those wheels you have are 9'5" wide, so the alternative if you keep them are 275/45 tyres.
Sat Mar 13 2021 7:33pm |
Flyfisherman Member Since: 12 Sep 2020 Location: Staffordshire Posts: 91 |
Hi Stunty I’m selling this set of wheels with 275/45/21 Pirelli scorpion all weather
Sat Mar 13 2021 8:07pm |
Sat Mar 13 2021 9:30pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
See now I think your pics in post #1 are fine. I run a different style of standard 20s’ with 275/40 and love the look. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Mar 14 2021 7:31am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 409 |
I echo Stevepd. Barrie.
Sun Mar 14 2021 10:03am |
If you want to fill the arches, you go for a high sidewall, not a short sidewall on a big rim. It gives a better ride too and also gives the rims some protection when you're parking up on the pavement to pick up your kids from school.
Sun Mar 14 2021 11:04am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Alternatively if you did not wish to the replace wheels or tyres you could always re-calibrate the ride height to lower the suspension, probably not the best if you go off road though as lowering standard ride height automatically changes the others heights the same amount. My own personal choice either 275/45 x 20" or 275/45 x 21"
Sun Mar 14 2021 9:51pm |
