Home > General > What Size Wheels/Tyres
Stunty
United Kingdom 2007 Range Rover Sport TDV6 HSE Siberian Silver
So I think these 20" rims, 275/40/20's just doesnt 'look' right? maybe too low a profile? would 21 or 22's help, or a different size altogether? Thoughts, pictures of what you guys are running..
Post #611432 Sat Mar 13 2021 5:36pm
They do look low profile and wide too.
Maybe wrong tyres fitted ? What does the manual say ?
I’d avoid 22s
Post #611434 Sat Mar 13 2021 6:23pm
275/40/20 is a correct size although on a 2007 2.7 it might be that you shouldn't have 20 inch rims fitted anyway. Early 2.7 weren't designed to have rims over 19 as the steering rack needed a damper. The V8 petrol and diesel had the damped rack. Not sure whether a 2007 2.7 would have it. 2012 SDV6 - it's missing a couple of cylinders
Post #611436 Sat Mar 13 2021 6:42pm
Ash3
Had 22s with 285/35 tyres on my Disco 3 MY2005 which mechanically was identical to L320.
Never had an issues re handling and ride...
Post #611437 Sat Mar 13 2021 7:06pm
Dave B
So those wheels you have are 9'5" wide, so the alternative if you keep them are 275/45 tyres.
These are the same wheels with the bigger tyres on my Disco.
Here are 20" 8.5" wide wheels with 255/55 tyres on the same car.
And here is my RRS with 21" wheels and 275/45 tyres.
As you can see, to fill the arches you either need to go to 255/55 x 20 or 275/45 x 21.
I have also sent you a PM, with a couple of options.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #611440 Sat Mar 13 2021 7:33pm
Flyfisherman
Hi Stunty I’m selling this set of wheels with 275/45/21 Pirelli scorpion all weather
Pm sent
[/b]
Post #611443 Sat Mar 13 2021 8:07pm
riverblanche
first pic is of standard 20" wheels with car in access mode, I preferred the ride on the second pic which were 255/55/19
Agree with above stick with 20" and put 45 profiles on, if that helps any
 Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #611448 Sat Mar 13 2021 9:30pm
Stevepd
See now I think your pics in post #1 are fine. I run a different style of standard 20s’ with 275/40 and love the look. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #611452 Sun Mar 14 2021 7:31am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I echo Stevepd. Thumbs Up Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #611457 Sun Mar 14 2021 10:03am
If you want to fill the arches, you go for a high sidewall, not a short sidewall on a big rim. It gives a better ride too and also gives the rims some protection when you're parking up on the pavement to pick up your kids from school.
The full drug dealer look, conversely, needs huge rims with spray on rubber.
So, drug dealer look or yummy mummy pavement-mounter - it's your choice. Rolling with laughter Rolling with laughter
This is my choice:
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #611458 Sun Mar 14 2021 11:04am
Alternatively if you did not wish to the replace wheels or tyres you could always re-calibrate the ride height to lower the suspension, probably not the best if you go off road though as lowering standard ride height automatically changes the others heights the same amount. My own personal choice either 275/45 x 20" or 275/45 x 21"
Post #611487 Sun Mar 14 2021 9:51pm
