![]() | Home > Maintenance & Modifications > Thermal jacket for main car battery |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 ![]() ![]() ![]() |
So -9 last night and possible -10 0r -12 tonight, and so I know the car wont start tomorrow.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
When you say poor starting or won't start is it that the engine won't turn over or just doesn't fire up?. I know that extremes of cold can affect battery performance, but if the battery is good the temp shouldn't cause that much difference. As Riverblanche says, do you not have a FBH fitted, this would make a massive difference. 2010 RRS, TDV8
Gents, the car turns over if and only if I use it every single day. If it sits for 2 days or more it then plays up.
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 ![]() ![]() ![]() |
The FBH heats the coolant.
You have problems other than just your battery - how many glow plug cycles do you go through on start - I go through at least 3 cycles when temps get below zero and it starts fine. We do not have FBH here and from yout comments you need to learn how they work as it will help your starts.
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
One of these, might be what you want......
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
One of the best things I ever did on my car was add the FBH controller. I use it every time I go out in the winter not just to help with starting but on the (unproven) premise that if the car is warmer at start up, there is less strain on engine parts in those first 5 minutes or so. I just click the third button on my key whilst I am finishing my cup of tea and half an hour later go out. And of course once I start the car and drive off, the heater warms up that much quicker.
Just reset mine, after changing my battery...
Thanks for all the responses folks.
You do not need to take the battery out to charge it - just make sure the -ive charging cable is on the stud just in front of the battery on the inner guard and not on the - ive battery terminal. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Didn’t Kev (knWatkins) have one for sale from his L320? 2006 2.7 TDV6 HSE in Cairns Blue. |
So do I really need to purchase an IID tool as well as the FBH remote? That’s putting a quick ‘cheap’ fix at close to £1000 |
