Home > Wheels & Tyres > Other than Pirelli? |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
My last set of tyres did exactly that, twitched and tried to follow white lines, road patches etc. it was quite unnerving especially in the wet. I put it down to having different fronts to rears, the previous set of Continentals didn't do that (would never recommend them though due to the bad edge wear). As mentioned above the crossclimates feel totally steady, no twitching or line following so far, so I'd think it was more tyre choice than RRS's. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Fri Jan 29 2021 10:19pm |
lkdgndg1 Member Since: 15 Jan 2021 Posts: 32 |
Some say to increase the size of the tyre to 275/45/20 instead of 275/40/20 as it’s a better ride , would this be ok or would it affect the Speedo reading . |
Fri Jan 29 2021 11:35pm |
I'm still to check mine against the GPS but I reckon it should be more accurate. I know the 40's were 3mph under at 60mph, so it should even it out. 13MY Range Rover Sport Autobiography SDV6 - mine
Fri Jan 29 2021 11:42pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
I have 275/45s and my speedo is spot on checked against TomTom GPS.
Sat Jan 30 2021 1:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5008 |
I have run both 275/45x20" and 275/45x21" and as Dave B said on the 21's it is spot on compared to GPS, we also have a lot of roadside speed warning cameras here and the digital readout on dash and camera are exactly the same so 20" rims should not make any real difference to worry about. If it's suggested suggest changing wheel/tyre size in the CCF files don't bother as it won't make a blind bit of difference to the speedo reading, except possibly to the mileage distance covered and dash mpg "lie 'o' meter" reading and that will be minimal.
Sat Jan 30 2021 9:35pm |
Strange thing is, my Disco Commercial is on 275/45x20s, and the speedo is again bang on with the GPS tachograph display.
Sun Jan 31 2021 12:35pm |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 |
For anyone who is running the General Grabber AT3, How do you find it for road noise, comfort and wear?
Tue Feb 02 2021 11:07am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
I found the Grabber AT3 to be very good on road. No noise issue (especially when compared to the previous version the AT which got a bit loud as it wore), wear seemed to be good. Only issue is that it is an AT so is a little compromised on road compared to a road tyre. But remembering that, it is an excellent all rounder. 2012 SDV6 - it's missing a couple of cylinders
Tue Feb 02 2021 5:25pm |
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 |
After one year on AT3 tyres and about 4-5000 miles I'm really pleased with them. No more noise or reduction in comfort compared to previous road biased Pirelli There is no replacement for displacement - W O Bentley
Tue Feb 02 2021 9:58pm |
That all sounds really positive for the AT3. I have never had tyres like this so have no reference to work from. Now I have located the cause of the noise coming from the passenger side, and cured that, there is practically no cabin noise and I don't want to spoil that if I can help it. My Pirellis were probably half worn when I got the car and I am not far off the limit now, so have never run it yet on 'New' tyres. Pete
Wed Feb 03 2021 9:41am |
gavcav Member Since: 07 Feb 2020 Location: Leeds Posts: 19 |
Anyone running the Goodyear Vector 4 season SUV Gen 3's? they do well in the Autobild 2020 tests but i've not heard of anyone running these or any comments on them? would be greatful for any feedback on this tyre?
Sat Feb 06 2021 7:40pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Just to add my ten penny worth, a word of caution if anyone is thinking of Uniroyal Rainsport 3 tyres. I found them great tyres with a low wear rate BUT after about a year or so of trying to find out why the RRS seemed to wander across the road I discovered that it was the tread pattern that was causing the problem. That was after many trips to the 4 wheel alignment place and driving my indie nuts by continually asking them to check and recheck bushes etc. I was on 275 40 20's. Now on Pirelli Scorpion Zero and they have cured the problem. Robin
Sun Feb 07 2021 8:35am |
Hi Robin.
Mon Feb 08 2021 4:16pm |
Yeh! Hence the advantage of the forum. Its not just for moans about poor engineering/build quality or poor dealer performance. You can tap into other peoples experience. It may not be the perfect answer for you but it sure helps guide your path. Robin
Mon Feb 08 2021 4:25pm |
