Home > Technical > Anti roll bar bushes - rubber or Poly? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Rubber tends to dry out and creak. We fit polys, and never had one come back |
Fri Feb 05 2021 12:12pm |
Sparkey Member Since: 03 Feb 2021 Location: Yorkshire Posts: 24 |
Cheers bud |
Fri Feb 05 2021 4:55pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Which ones do you use out of interest? I have them on my front ARBs and I've not heard a knock in 40k+ miles. Will likely replace any other with poly as they come to need replacement |
Fri Feb 05 2021 6:09pm |
SuperPros going in mine front and rear on Wednesday 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Feb 06 2021 10:52am |
I've seen online that there are two types,
Sat Feb 06 2021 12:56pm |
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 |
If you pop the bonnet and check to see if you have an extra fluid reservoir with a yellow cap (like your power steering) on the front left hand side of the engine bay, if you have this then you have hydraulic ARBβs then you have ACE/Dynamic Response
Sat Feb 06 2021 2:03pm |
Thanks Lee!
Sat Feb 06 2021 4:35pm |
