![]() | Home > General (L494) > Range Rover Sport l494 2014 rear differential control module |
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 ![]() ![]() |
Here you go
Unclebuck Member Since: 04 Dec 2014 Location: South Yorkshire Posts: 51 ![]() ![]() ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
It's that one. ![]() Changing the module requires a calibration to be performed so might not be a DIY job unless you have access to a suitable device. Here's an excerpt from the workshop manual. https://www.rrsport.co.uk/gallery/albums/u...20L494.pdf 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks for the help but the schematics you showed are the same ones I copied from the Topix web, the one you identified as being the rear diff control module, as a label on the other side (which is in the photos) I believe from the number relates to the Automatic gearbox module! Please advise thanks |
The rear diff control module part number I have been advised it is is HY32-4C117-AD, the auto transmission module in the photo is EX53-4C118-AD unless I’m mistaken? |
I wonder if there is a confusion of part names / numbers. The automatic transmission control module (TCM) is in the gearbox itself. The transfer box control module TCCM is in the centre console next to the Terrain Response switches. Maybe the box that you have is the rear diff controller but has been given a different name and hence part number somewhere along the way. 2012 SDV6 - it's missing a couple of cylinders
Can anyone confirm the correct part number for the rear diff control module? Thanks |
Yes I’m beginning to think the same! If you google the part numbers that I have listed one comes up as the rear diff control module and the other (the one in the photo) as transmission module! Yet everything I seem to read states that the one in the photo i found is the rear diff control module ! But I can’t think how the transmission module is the same as the rear diff. Anyone help? Thanks |
I belive its the right part why not disconnect it and see what errors come up to confirm its the diff unit |
Update! Having taken my car before Xmas in to diagnose the issue with the ‘E-Diff warning’ etc, I was advised that the issue was with the Differential locking motor which sits on top of the rear diff and not the control module. So I purchased a new differential locking motor using the part number supplied by the garage ! They advised that it would need ‘coding’ so I got the part for them to fit. The locking motor I purchased using the part number supplied was the wrong motor ! The garage had removed mine and had to refit it back once they noticed the differences. The one I bought is more readily available than the one I needed and a third of the price! Typical ! Luckily I could return the bought item, but prior to buying the correct motor, I decided to swop the rear diff control module and see what would happen and guess what the dreaded ‘E-Diff warning message etc’ has cleared and I didn’t need to be recoding result!
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Great result. Nice one 2022 P440e AB |
Nice to get a good result. |
Basketcase Member Since: 12 Oct 2021 Location: Norwich Posts: 3 ![]() ![]() |
Hopefully my recent experience sorting a similar problem may be helpful to others:
