Home > General (L494) > Range Rover Sport l494 2014 rear differential control module
Unclebuck
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Hi, I need to replace the rear differential control module, Part number (i believe) is HY32-4C117 AD
It was diagnosed being faulty after the 'E-Diff Not Working ' warning popped up!
I went on Topix spent my £20 for the hour and located and viewed the removal procedure. Topix shows the module on the right rear drivers side somewhere behind the panel behind the rear fuse box area.
Tried to find it today and the Module isn't there? managed to find the auto transmission module but no other! Could any one help? Thanks
Post #609140 Mon Jan 25 2021 1:50pm
SC247
Here you go
Post #609143 Mon Jan 25 2021 3:09pm
Unclebuck
Hi, thanks for the schematics, that is where I was hoping I should find it! but all I can see when I have stripped it down is as in these photos and according to the part number that is the auto trans module? Any further help would be much appreciated!
Post #609148 Mon Jan 25 2021 4:02pm
Unclebuck
Try these the correct way round
Post #609149 Mon Jan 25 2021 4:06pm
Unclebuck wrote:
It's that one. Thumbs Up
Changing the module requires a calibration to be performed so might not be a DIY job unless you have access to a suitable device.
Here's an excerpt from the workshop manual.
https://www.rrsport.co.uk/gallery/albums/u...20L494.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #609152 Mon Jan 25 2021 5:20pm
Unclebuck
Thanks for the help but the schematics you showed are the same ones I copied from the Topix web, the one you identified as being the rear diff control module, as a label on the other side (which is in the photos) I believe from the number relates to the Automatic gearbox module! Please advise thanks
Post #609155 Mon Jan 25 2021 6:10pm
Unclebuck
The rear diff control module part number I have been advised it is is HY32-4C117-AD, the auto transmission module in the photo is EX53-4C118-AD unless I’m mistaken?
Post #609157 Mon Jan 25 2021 6:17pm
I wonder if there is a confusion of part names / numbers. The automatic transmission control module (TCM) is in the gearbox itself. The transfer box control module TCCM is in the centre console next to the Terrain Response switches. Maybe the box that you have is the rear diff controller but has been given a different name and hence part number somewhere along the way. 2012 SDV6 - it's missing a couple of cylinders
Post #609171 Mon Jan 25 2021 8:36pm
Unclebuck
Can anyone confirm the correct part number for the rear diff control module? Thanks
Post #609176 Mon Jan 25 2021 8:44pm
Unclebuck
Yes I’m beginning to think the same! If you google the part numbers that I have listed one comes up as the rear diff control module and the other (the one in the photo) as transmission module! Yet everything I seem to read states that the one in the photo i found is the rear diff control module ! But I can’t think how the transmission module is the same as the rear diff. Anyone help? Thanks
Post #609179 Mon Jan 25 2021 8:56pm
SC247
I belive its the right part why not disconnect it and see what errors come up to confirm its the diff unit
Post #609207 Tue Jan 26 2021 7:59am
Unclebuck
Update! Having taken my car before Xmas in to diagnose the issue with the ‘E-Diff warning’ etc, I was advised that the issue was with the Differential locking motor which sits on top of the rear diff and not the control module. So I purchased a new differential locking motor using the part number supplied by the garage ! They advised that it would need ‘coding’ so I got the part for them to fit. The locking motor I purchased using the part number supplied was the wrong motor ! The garage had removed mine and had to refit it back once they noticed the differences. The one I bought is more readily available than the one I needed and a third of the price! Typical ! Luckily I could return the bought item, but prior to buying the correct motor, I decided to swop the rear diff control module and see what would happen and guess what the dreaded ‘E-Diff warning message etc’ has cleared and I didn’t need to be recoding result!
The module is situated in the place you guys stated and was easy to swop.
Thanks for all your help.
Post #609921 Fri Feb 12 2021 10:26pm
PauloAmore
Scotland
Great result. Nice one 2022 P440e AB
Post #609925 Sat Feb 13 2021 9:36am
Nice to get a good result. Thumbs Up
Perhaps you need to change garages. Are you using an LR indie or a regular garage? 2012 SDV6 - it's missing a couple of cylinders
Post #609944 Sat Feb 13 2021 3:11pm
