Home > Faults & Fixes > Front Right oil leak, suspect it’s ARB.
Page 2 of 3 <123>
RRT
Excuse my zero knowledge.
I like the end job, but could the pipes be replaced with a flexible braided hydraulic pipes with the couplings or wouldn't the couplings fit through the gap? MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #583864 Fri Jul 12 2019 10:45am
Brit Plumber
I reckon they would fit through the gap ok and as long as the pipe is rated above say 450-500 Bar (that gives a safety margin above the max operating pressure of the system). It would need to be secured to the chassis as you wouldn’t want a flexible pipe snagging on anything. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583868 Fri Jul 12 2019 11:45am
jimmybee
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Java Black
awesome thanks for response
Post #583869 Fri Jul 12 2019 11:56am
knwatkins
Out of interest, did you fit dampers or leave it as it was without them? Kev
Post #584585 Sun Jul 28 2019 9:53am
Brit Plumber
Is that a question for me?
I didn’t fit them as I read in the WS manual it said to remove and dispose of as they are not required. I have a feeling that they didn’t fit them after a certain VIN and made it a retrospective action to not refit them if removed on older vehicles. 2019 5.0 SC SVA (Current)
Post #584592 Sun Jul 28 2019 1:21pm
knwatkins
Yes it was and thanks.
I checked and mine doesn't have them either. Kev
Post #584622 Mon Jul 29 2019 10:57am
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi Britplumber, hoping to get some help and advise based on your repair on the hydraulic pipes on your range rover. i have the lower pipe corroded, can you help me with...
1. What size pipe do I need? is it flexible or fixed?
2. What type of coupler?
3. how do i cut with a regular saw?
Thanks for the advise and support
Jig
Post #609107 Sun Jan 24 2021 7:47pm
jig
How do I cut these pipes? Angle grinder hand saw, is there risk of filings getting into the system?
If the pipes are quite rust will the compressor fitting still fit?
Going to a hyraulic place this afternoon, is flexibl pipe better? what thickness pipe and bore?
Thanks
Post #609119 Mon Jan 25 2021 8:57am
jig
bump
Post #609121 Mon Jan 25 2021 9:47am
Brit Plumber
I’ve replied to your PM. 2019 5.0 SC SVA (Current)
Post #609126 Mon Jan 25 2021 10:45am
Yanee6804
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Fuji White
Hi guys
I have a same issue with my pipes
Please help
Can I replace the damaged part of pipe for mild steel pipe 10mm OD 1mm wall thickness and mild steel compression coupler 500 bar rated
Many thanks
Post #639725 Fri Feb 16 2024 10:09pm
Brit Plumber
Yes you can, but I’d go for Stainless as the price difference is minimal. Also, you will need to cut back to area with no corrosion so the olives can seal. Any pitting or ovality in the pipe risks a leak. 2019 5.0 SC SVA (Current)
Post #639726 Fri Feb 16 2024 10:38pm
Yanee6804
Thanks Plumber
Really appreciate
I see my next challenge
Clean the tubes😁😁
Also thinking to put double ferrule couplers
Post #639727 Fri Feb 16 2024 11:14pm
Disco_Dave
Hi Britplumber,
Many thanks for all your input to the others on here with this issue which I have as well - I've recently bought a RRS 2010 vintage - bought it as a 'good deal' with no MOT Laughing but...
It's since failed MOT on the same issues you and the other guys in this thread have had, i.e. hydraulic fluid spraying everywhere! Someone had attempted to replace a section of one of these pipes with rubber hose which had split - my local non-specialist RRS mechanic tried to replicate that with new and better rubber hose which of course failed as well.
I've done a fair bit of research now (which I should have done before I bought the car, I know...), talked to many people and was close to giving up hope but then came across this forum and your posts and now have a bit more confidence that I have another choice other than paying 2-3k for a specialist/main dealer repair or selling it for spares/as a non-runner. Really hate to give up on anything so although head says get rid, heart says it's a great car to drive and why should I let a foot long section of pipe defeat me?!?
Sorry for the saga but I feel a lot better about things now - I just need to get down to the job.
I notice you live in Sleaford as well so may well pass you on the road when I have my RRS up and running - I may pm you as well with further tech queries as I get down to the job.
Thanks again,
Dave
Post #639920 Fri Feb 23 2024 12:01pm
Disco_Dave
Hi again Britplumber,
Just wondered if the WS manual you referred to earlier was a Haynes one or a genuine LR one?
Cheers,
Dave 2010 3.0 TDV6
1999 V70 T5
Post #639921 Fri Feb 23 2024 1:01pm
Page 2 of 3 <123>
