![]() | Home > Faults & Fixes > Front Right oil leak, suspect it’s ARB. |
I reckon they would fit through the gap ok and as long as the pipe is rated above say 450-500 Bar (that gives a safety margin above the max operating pressure of the system). It would need to be secured to the chassis as you wouldn’t want a flexible pipe snagging on anything. 2019 5.0 SC SVA (Current)
jimmybee Member Since: 11 Jul 2019 Location: Liverpool Posts: 3 ![]() ![]() ![]() |
awesome thanks for response |
Out of interest, did you fit dampers or leave it as it was without them? Kev
Is that a question for me?
Yes it was and thanks.
jig Member Since: 14 Jan 2018 Location: London Posts: 40 ![]() ![]() |
Hi Britplumber, hoping to get some help and advise based on your repair on the hydraulic pipes on your range rover. i have the lower pipe corroded, can you help me with...
How do I cut these pipes? Angle grinder hand saw, is there risk of filings getting into the system?
bump |
I’ve replied to your PM. 2019 5.0 SC SVA (Current)
Yanee6804 Member Since: 12 Apr 2021 Location: Essex Posts: 20 ![]() ![]() ![]() |
Hi guys
Yes you can, but I’d go for Stainless as the price difference is minimal. Also, you will need to cut back to area with no corrosion so the olives can seal. Any pitting or ovality in the pipe risks a leak. 2019 5.0 SC SVA (Current)
Thanks Plumber
Disco_Dave Member Since: 23 Feb 2024 Location: Sleaford, Lincs Posts: 2 ![]() ![]() ![]() |
Hi Britplumber,
Hi again Britplumber,
