Home > General (L494) > Part number for MY16 rear view mirror with high beam assist |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
No Probs mate keep us posted If a jobs worth doing, get a someone who knows what they are doing to do it!
Mon Oct 26 2020 10:24am |
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 |
Hi finally got the mirror ECU on the network have programmed it with my GAP tool but have a fault message stating that it is mechanically miss allined does anyone know how to rectify |
Wed Nov 04 2020 9:08am |
Not sure on that one maybe it thinks its not level perhaps maybe remove it and then restart car then put it back on again? If a jobs worth doing, get a someone who knows what they are doing to do it!
Wed Nov 04 2020 9:59am |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 |
If anyone is looking for a mirror to retrofit high beam assist to a pre-MY16 car then I'm selling one...
Wed Nov 04 2020 1:18pm |
It worked thanks |
Thu Nov 05 2020 10:50am |
No probs chap glad its all working If a jobs worth doing, get a someone who knows what they are doing to do it!
Thu Nov 05 2020 11:09am |
Edgtg Member Since: 23 Jan 2021 Location: New York Posts: 1 |
Hi how did you get it to show up on ecu list having same problem on a 2016. |
Sat Jan 23 2021 2:38am |
HI Edgtg I repleid on the .net site but to keep it here too I didi and ECU Scan from in the IID Config menu called Find ECU's and then did a scan ECU's from the main menu, not sure if the scan will only work on the current ECU' list it has and maybe there is a defualt list already built in my guess is that the find ecus list if stored on the tool and would be used if a new EUC had been fitted so maybe this is worht a shot (if not then we will have to keep thinking!)
Sat Jan 23 2021 11:27am |
I replaced my ODB port as the GAP tool could not fully connect to the CAN networks due to the contacts of my old ODB port were weak and bent |
Sat Jan 23 2021 11:42am |
ah yes that makes sense then (too much gap tool use eh!) If a jobs worth doing, get a someone who knows what they are doing to do it!
Sat Jan 23 2021 3:38pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
I'm looking into this and trying to find the right mirror for my 2016MY Autobiography.
Wed Feb 03 2021 10:26am |
Try the US |
Wed Feb 03 2021 10:35am |
Yes US is probably the best bet, ive just PM a guy on here who might have one that could work, he is trying the same thing but I think he had one for a later car which crashed his can bus but this might work for yours as its a 2016 so the backedn software is newer than the 2014-2015 cars.
Wed Feb 03 2021 11:07am |
That would be great if he has one 2016 Black SDV8 Autobiography
Wed Feb 03 2021 2:48pm |
