![]() | Home > Technical > Possible oil leak from left bank, help! |
drexal Member Since: 17 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hello all,
Hi Andy, thanks so much for replying. Ahh ok, that doesn't sound so bad. Do you have a rough ball park figure how much a independent specialist would charge for a cam cover gasket change?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Maybe 1.5 hours to change gasket on 4.2
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
I think you will find you may have to remove the Supercharger on a 5.0L to gain access to the cam cover inner retaining bolts, there is also a special tool to align the cover when refitting. Could also check for any excessive backlash in the s/c nose cone as the tvs1900 s/c did suffer a bit with wear in the torsional isolator coupling and spring which I believe made a rattling knocking noise. If you remove the s/c belt not to difficult to do, should be able confirm if that is the noise though.
Thanks both for replying. Wow you guys are so knowledgeable. If this was your car would u attempt to try an replace the gasket yourself or would I give to a independant specialist?
I recently replaced both the accessories and supercharger belts on mine, S/C one is easy as comes off first, just had a read of the Powertrain section of the W/Shop manual for the 5.0L S/C engine first.
Hi Col, thanks again for always replying, i wish i could find a way to upload or send you the video, the knocking sound is very faint. But i don't remember hearing this in the past.
Before or after the Vin No. I quoted. do you not have a copy of the W/Shop manual?
Hi Col, my vin says something like CA7odd Iβll find full number when I get in if it helps?
Hi Col,
Time is something I have quite a bit off these days as called it a day and decided to retire to NZ. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Whilst I'm not a big fan of black cars (wash it, drive it; dirty again |
Wow Col,
