Just watched that video, not sure I personally would want to tackle it so keep fingers crossed never have a cam cover leaking, If anyone had the facilities might be easier to lift the body as I believe that is only a couple of hours work, but may be wrong on that one.
Thanks for your comments, no I didn't buy the car new it was a few months old when I bought it, was spur of the moment purchase, had a test drive in friends fullfat S/C and thought I have to have one of these not the fullfat but a Sport, went out the next day and bought the one I still have, I already had a TDV8 which was a cracking car so kept both for a few months to see which I preferred, needles to say the S/C won. They were few and far between when I bought it could only find two for sale on L/R approved used car list, actualy bought it from Guy Salmon in Sheffield. It has all the usual standard A/B extras plus few extra options like RSE, surround cameras, dual view screen, sunroof, TPMS system, side steps, tow bar etc. so quite a lucky find in some ways, not that they make it worth anymore maybe just a little more desirable when selling.
The the body kit I bought from Overfinch and fitted myself, only used the bumpers, exhaust tips and undertray though as the door side trims don't fit if you have side steps, the mirrors are from a disco 4.5 but basically bolt straight on, steering wheel, gear knob and silver interior switch/vent trims etc. came from powerful uk. thought they just give a bit of contrast to the black plastic, just wanted to make the car a little different without hopefully going completely OTT. Have had it re-mapped and S/C pulley upgraded as well not that it needed it but because I could, also fitted a set of the early SVR 21" rims.
Brake discs and pads are EBC, the pads are actualy redstuff but no longer available, only pad I found that did not make a sound when braking, although I believe the yellowstuff is a good alternative by all accounts.
