Home > Technical > Active control roll module
Page 3 of 3 <123
Simon_CSK
Disco_Mikey wrote:
OK, but what fault codes?
See above
U0434 Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #608032 Thu Dec 31 2020 1:51pm
I think Mike thinks there should be more fault codes, with those dash messages.
What about the air suspension module, what codes does that have?
Post #608035 Thu Dec 31 2020 3:04pm
Simon_CSK
Those are the codes and the messages. There is no more.
I can't give back ground either as I bought it in a salvage auction. Current cars
Range Rover CSK
Discovery 3 HSE
Post #608038 Thu Dec 31 2020 5:19pm
Disco_Mikey
Simon_CSK wrote:
See above
U0434
Fault codes in modules other than the ARCM. Such as the RLM, PCM etc
Post #608040 Thu Dec 31 2020 6:01pm
Disco_Mikey
The 2 digits after U0434 would also help Thumbs Up
Post #608041 Thu Dec 31 2020 6:02pm
Disco_Mikey
Also, the WSM doesn't list U0434 as a possible fault code for the ARCM Confused
Post #608042 Thu Dec 31 2020 6:10pm
Simon_CSK
Screen shot from computer. The fault at the top was cleared Current cars
Range Rover CSK
Discovery 3 HSE
Post #608043 Thu Dec 31 2020 7:00pm
Disco_Mikey
Right. So...
Your reading the faults from the RLM (air suspension)
The warning messages you are having displayed on the dash, are faults with the ARCM
Your reading the codes from the wrong module...
Post #608046 Thu Dec 31 2020 7:42pm
Simon_CSK
Where should I be looking? Current cars
Range Rover CSK
Discovery 3 HSE
Post #608049 Thu Dec 31 2020 10:07pm
I thought the actual ARCM module it's self is located in a similar position only on the passengers side of the vehicle. This is the only code I can see which begins U0434 but not saying there isn't any others.
Post #608050 Thu Dec 31 2020 11:00pm
Disco_Mikey
ARCM Neutral
Active Roll Control Module
Dynamic Repsonse Module
Different computers call it different things...
Post #608051 Thu Dec 31 2020 11:00pm
Disco_Mikey
Passenger side on an LHD car, drivers side on RHD
The RLM is logging the U0434 comms error, as the ARCM is logging a hard fault...
Post #608052 Thu Dec 31 2020 11:02pm
Did actualy wonder as it was a L/H/D illustration I was looking at, although it did mention location as drivers side.
Post #608053 Thu Dec 31 2020 11:18pm
RRSCruiser
2007 Range Rover Sport TDV8 HSE Santorini Black
Simon_CSK wrote:
Mikey
I don't know what the new one is from. I would suspect from a V6 next thing to do now is get it back on the computer and make sure it is configured properly. I am at the extent of my skills so it is garage bills from here unfortunately.
Hi Simon
I know this is an old thread but could i ask how you got this replacement configured, I have a TDV8 and have sourced and bought what looks like a TDV6 ARC module, I didn't know they needed programming so one step forward and two back unless the GAP IID can configure it
How did you get this problem resolved?
Kind regards
Stuart
Post #634367 Tue Jul 18 2023 4:25pm
Simon_CSK
I would love to help but cannot remember which car it was. I have owned many RR Sports in the last three years and currently have 5 all of which are unlikely subjects as three of them are spares cars.
I suspect that the problem was either resolved by changing the module or the car was broken up. If I was to guess the car I would think it was one where I blew the turbos not long after sorting it and ended up for spares for my current car. Current cars
Range Rover CSK
Discovery 3 HSE
Post #634373 Tue Jul 18 2023 7:02pm
Page 3 of 3 <123
