![]() | Home > Technical > Active control roll module |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
With a suitable diagnostic tool |
As long as you don't say Snap on, or Autel |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 ![]() ![]() ![]() |
OK got the part and have fitted it in a manner.
If there is no change, that suggests that the original module isn't faulty |
Mikey
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
What led you to believe the original module was faulty and not possibly one of the two accelerometers being the suspect.?
Fault code came up on the computer and when I researched the meaning of the code there were 3 possible solutions. The first was the ACRM and the other two were wiring to the same. Easy to start with thecomponent. Current cars
What codes did you have? |
U0434 Current cars
And codes from the other modules?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
Do you have any warning lights or dash messages while driving ? |
Suspension Fault
OK, but what fault codes? |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
I currently have the same problem as you with the same message on the dashboard. I have replaced the ACR module with a brand new one from Land Rover and had it coded in etc and it didn't fix the issue.
