Home > Technical > Active control roll module
Page 1 of 3 123>
Simon_CSK
Where is this box of tricks located? Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #607876 Sat Dec 26 2020 8:07pm
Disco_Mikey
Base of A pillar, underneath the RLM Thumbs Up
Post #607877 Sat Dec 26 2020 9:24pm
Simon_CSK
Thanks Mikey
Nearside A pillar? Inside cabin?
RLM? Current cars
Range Rover CSK
Discovery 3 HSE
Post #607879 Sat Dec 26 2020 10:08pm
Disco_Mikey
Offside
Inside car
Ride Level Module
Post #607888 Sun Dec 27 2020 6:20am
Simon_CSK
Perfect thanks. Current cars
Range Rover CSK
Discovery 3 HSE
Post #607891 Sun Dec 27 2020 7:59am
idi
Does the instrument cluster need to be removed for it to be accessed?
Post #607916 Mon Dec 28 2020 2:29pm
Disco_Mikey
No Thumbs Up
Post #607921 Mon Dec 28 2020 2:48pm
Simon_CSK
I have taken the panel under the steering wheel off and the panel at the side of the accelerator and couldn't see it is it up high or down low? Current cars
Range Rover CSK
Discovery 3 HSE
Post #607935 Mon Dec 28 2020 7:27pm
Disco_Mikey
Relatively low. Not sure i have a pic of its location on my phone. Its just, there... Laughing
Post #607948 Mon Dec 28 2020 8:59pm
Disco_Mikey
RLM is located above the ARCM. That is a pic of the RLM, albeit on a Discovery, but its in exactly the same place
Post #607949 Mon Dec 28 2020 9:03pm
Simon_CSK
Thanks Mikey
Every little scrap of info will help. Am getting the replacement part next week so not in a hurry to pull the car apart until I am ready to go. Am hopeful this will cure my problem and I will be able to get the car useable. Current cars
Range Rover CSK
Discovery 3 HSE
Post #607952 Mon Dec 28 2020 10:34pm
idi
Out of interest, what is the problem with the car?
Post #607953 Mon Dec 28 2020 10:56pm
Simon_CSK
The car is reporting problems with the suspension which is putting it in limp mode, The computer puts out an error code that points to the Active roll control module or associated wiring.
First job therefore is to replace the module, If the replacement doesn't work I will first try one from another car that I know works then will go in search of wiring problems.
However the first job is to locate the little critter Rolling with laughter Rolling with laughter Rolling with laughter Current cars
Range Rover CSK
Discovery 3 HSE
Post #607958 Tue Dec 29 2020 7:57am
Make sure the replacement module is configured for the TDV8 as they had two tunes in them, one for the TDV6 and V8 petrol and the other for the TDV8.
Post #607959 Tue Dec 29 2020 8:22am
Simon_CSK
Do you know how to configure them? Current cars
Range Rover CSK
Discovery 3 HSE
Post #607976 Tue Dec 29 2020 5:41pm
Page 1 of 3 123>
