Home > General > L320 supercharged poor cabin heat
Themoog
Hi. Our L320 cabin heating does not get as hot as it should do and the passenger side only blows cold.
Is this something to do with the blend motors or could it be an auxiliary water pump failing?
The reason I mention the latter is because of a bmw video I saw that had just that problem.
The aux pump had failed so hot water was not being pushed through the heater matrix fast enough to give sufficient heat to the cabin.
I'm not sure if the RR has a similar set up.
Can anyone shed any light on this?
Post #607881 Sat Dec 26 2020 10:33pm
The matrix gets blocked in the diesels to cause this. Probably favourite.
Jags have pumps but that would effect both sides
Post #607885 Sat Dec 26 2020 11:52pm
Disco_Mikey
Done many matrixes (?) on diesel models, coolant gels up in the LH extremities, and restricts flow to the passenger side
I would imagine petrol models would suffer the same fate
Post #607889 Sun Dec 27 2020 6:22am
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
is there a way preventing this matrix failure :L RRS TDV6 2010 Smile
Post #607956 Tue Dec 29 2020 7:30am
Themoog
Maybe a powerful back flush?
Could it have anything to do with my lpg acting up as that uses coolant to regulate.
Post #607960 Tue Dec 29 2020 9:06am
Disco_Mikey
Regular coolant changes
Flushing will likely do nothing, other than waste time and dilute your coolant mixture
Post #607970 Tue Dec 29 2020 2:34pm
Themoog
How can a flush dilute the coolant if it's replaced after. Confused.com
Post #607982 Tue Dec 29 2020 9:55pm
Disco_Mikey
No one mentioned anything about replacing the coolant, only flushing the matrix... Confused
Most people will flush the matrix, connect the hoses and top up with water. Not many will have a couple litres of anti freeze to replenish when done
Post #607983 Tue Dec 29 2020 10:22pm
