Home > Technical > DSC light comes on when turning right.
Pufftmw
LINK
Post #607622 Thu Dec 17 2020 9:30pm
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
So today...... Started the car, went to release park brake.... Followed by a loud screeching sound..... Park brake error....
Had to activate the emergency release on the park brake.
Do you think I maybe had a failing epb which was causing the DSC issue? Or just an unlucky second issue Big Cry
Post #607673 Sat Dec 19 2020 1:54pm
Could be.
As I said. Check the temperatures of the wheels (with hand) after a journey.
Check left matches right.
Post #607674 Sat Dec 19 2020 3:11pm
Pufftmw
I think unlucky 2nd issue
Post #607680 Sat Dec 19 2020 5:34pm
Jampot1979
So, garage managed to relatch my park brake and reset/adjusted the brake shoes. Luckily the epb module seems ok.
Also the DSC hasn't been an issue since. Maybe rear shoes were binding or something which set the DSC off etc.
Time will tell.
Post #607794 Wed Dec 23 2020 10:02am
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Are your tread depths even? I had a very similar problem after replacing2 tyres on the rear axle ( due to puncture) with new, (12mm) front were on about 4 mm so left them. I had DSC coming on at roundabouts and the car didn’t feel right at all. Replaced the front two tyres then everything was spot on again. Pressures were fine, it was the difference in tread depth that caused it.
Post #607859 Fri Dec 25 2020 7:48am
