Home > Technical > DSC light comes on when turning right.
Jampot1979
My 08 RRS has an issue which comes and goes. When going right or around a roundabout the DSC light comes on and it feels as if the front left-hand wheel is braking.
I have recently changed my wheels and it seems to do it more often now. I have checked tyre pressures and fluid levels etc.
Going to my local garage on Wednesday for them to plug it in and see if any codes etc show.
Not sure what it could be 🤔
Post #607481 Mon Dec 14 2020 5:08pm
steering angle needs calibration probably
You can press the DSC switch to stop it doing it.
Post #607482 Mon Dec 14 2020 5:33pm
Could be an ABS sensor has been knocked when the wheels were changed. That would give it the willies in certain situations. 2012 SDV6 - it's missing a couple of cylinders
Post #607497 Mon Dec 14 2020 11:41pm
Jampot1979
Thanks guys.
If I turn DSC off, the problem does go away. So something is being over sensitive/faulty or needs calibration.
Hopefully my local garage can runs some checks when plugged in.
Post #607535 Wed Dec 16 2020 7:53am
if you have an IID you can calibrate yourself
Post #607549 Wed Dec 16 2020 12:08pm
Jampot1979
I dont have one Sad
Post #607550 Wed Dec 16 2020 12:09pm
Jampot1979
Think problem solved...
Garage couldn't find any codes logged. They checked tyres pressures again and noticed they were all over the place, even though I checked them at a petrol station (think there gauge must be wrong)
Now got 36psi in each. DSC hasn't come on since. Chucked it around a few corners and seems fine. Time will tell...
Didn't think DSC would be so sensitive to tyre pressures.
Post #607556 Wed Dec 16 2020 4:22pm
garrycol
Australia
"Didn't think DSC would be so sensitive to tyre pressures"
DSC activating is often one of the first indicators that a tyre is deflating. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #607579 Thu Dec 17 2020 2:39am
Jampot1979
Censored !... The DSC activated once on the way to work this morning. Its certainly better than it was, but still a niggle.
So maybe 4 wheel alignment is my next thing to have checked.
My local garage did plug it in yesterday and there wasn't any faults logged.
Changing the wheels/tyres has certainly upset something slightly.
Post #607582 Thu Dec 17 2020 8:40am
36psi all round is a bit low at the back (or high at the front if you prefer). I'd put the pressures to standard (on the label on the driver's door) and then work from there. I tend to run my fronts a couple of psi higher than standard because I find the ATs I run are happier that way. With a pure road tyre, the pressures should work better if the relationship between front and rear pressures follows the standard. i.e. if you go up a couple at the front, go up a couple at the rear too. 2012 SDV6 - it's missing a couple of cylinders
Post #607585 Thu Dec 17 2020 9:26am
Jampot1979
I will try 33psi at front and 36psi at rear as per what is says on the door sticker. I have new michilens tyres fitted.
Would 3psi really make a difference?
Gotta love these RRS 😜
Post #607590 Thu Dec 17 2020 10:35am
Also check the rear wheels (brakes) aren't hot on one side compared to the other. After a journey
e.g a sticking calliper
Post #607593 Thu Dec 17 2020 12:00pm
Jampot1979
So adjusted the pressures to 33psi front and 36psi rears. Driven it around lots of twisty roads and roundabouts and it's behaved.
The rear passenger tyre had lost a few psi over the night. Found that the valve core was abit loose so nipped it up.
Let's see how I get on tomorrow 😜
Post #607607 Thu Dec 17 2020 4:50pm
Pufftmw
I had a very similar problem to you though the effect varied sometimes. Had steering sensor done, made it slightly better. Played around with tyre pressures, no discernible difference. It was a real pain with a trailer on the back!
I eventually had the front Brembo callipers rebuilt as I had a sticking driver's side. This cured it immediately, so mech and I believe that the n/s/f calliper was slightly sticking so when turning right under load made the DSC believe it was locking up or spinning? Whichever.
If you've got Brembos, there's a rebuild kit on eBay for about £70 for both sides - new pistons, seals and other bits. Tyre pressures really shouldn't be that sensitive and affect DSC etc, so is worth checking out.
Post #607609 Thu Dec 17 2020 6:08pm
Jampot1979
Hmmm.. that's food for thought. I do have brembos and have had constant sqeauling brakes for ages. What you say does make alot of sense. This is definitely something I will look into if problem persists.
Do you have a link to the rebuild kit?
Thanks again 👍
Post #607610 Thu Dec 17 2020 6:23pm
