Home > In Car Electronics > RRS L320 2013 License plate lights both out help !!!
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi my RRS L320 2013 number plate lights both out which fuse would I check I have seen mentioned Fuse 4 in glovebox it’s weird both lights out at same time.I don’t appear to have any other lights out.Going to check bulbs tomorrow are the fittings easy to get out of tailgate to change bulbs? Appreciate any guidance that can be given thanks folks Bow down
Post #607217 Fri Dec 04 2020 9:31pm
The Rear no. plate lamps are powered from the n/s rear light, so unless the n/s/r light it out as well I don't think it will be a fuse, but if it is worth checking Fuse No. 25. Easy enough to change the bulbs though, just flip the lamp out with small blade screwdriver.
Fuse No. 4 is listed as auto dimming rear mirror so not sure that would be of any relevance.
Post #607219 Fri Dec 04 2020 10:42pm
Iomegas
Thanks for your reply really appreciated I will have a look tomorrow .
Steve
Post #607220 Sat Dec 05 2020 12:14am
Knam
2012 Range Rover Sport SDV6 HSE Orkney Grey
Had exactly the same problem recently. The symptom was glovebox fuse 25 blowing constantly. Two wires to one of the light fittings had shorted out just about 12 inches up from the bulb housing, indie found it and fixed it quickly.
Post #607224 Sat Dec 05 2020 10:24am
Deleted.
Post #607225 Sat Dec 05 2020 11:28am
Disco_Mikey
Youd be surprised how many times it is 2 bulbs, and nothing more...
Post #607226 Sat Dec 05 2020 11:39am
Knam
Apologies, should have added, I had dodgy n/s/r light at same time. Also now ok
Post #607229 Sat Dec 05 2020 3:02pm
Pufftmw
Just happened to look at the back of my car in the dark and both my no plate lights are out Big Cry
Post #607234 Sat Dec 05 2020 5:21pm
Iomegas
Hi folks thanks for the advice it was both the bulbs had blown!!!! One thing the left hand lens for number plate the wire that holds the fitting to go into the lens casing is so short and fiddly couldn’t Land Rover have just given an extra 1 inch of length in wire!!! Lol
Post #607237 Sat Dec 05 2020 6:20pm
