![]() | Home > In Car Electronics > RRS L320 2013 License plate lights both out help !!! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
The Rear no. plate lamps are powered from the n/s rear light, so unless the n/s/r light it out as well I don't think it will be a fuse, but if it is worth checking Fuse No. 25. Easy enough to change the bulbs though, just flip the lamp out with small blade screwdriver.
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 213 ![]() ![]() ![]() |
Thanks for your reply really appreciated I will have a look tomorrow .
Knam Member Since: 06 Apr 2020 Location: UK Posts: 2 ![]() ![]() |
Had exactly the same problem recently. The symptom was glovebox fuse 25 blowing constantly. Two wires to one of the light fittings had shorted out just about 12 inches up from the bulb housing, indie found it and fixed it quickly. |
Deleted.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
Youd be surprised how many times it is 2 bulbs, and nothing more... |
Apologies, should have added, I had dodgy n/s/r light at same time. Also now ok |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Just happened to look at the back of my car in the dark and both my no plate lights are out |
Hi folks thanks for the advice it was both the bulbs had blown!!!! One thing the left hand lens for number plate the wire that holds the fitting to go into the lens casing is so short and fiddly couldn’t Land Rover have just given an extra 1 inch of length in wire!!! Lol |
