Home > Technical > ACE leaking
Page 4 of 5 <12345>
knwatkins
Great job, glad you got it sorted Thumbs Up Kev
Post #606897 Sun Nov 22 2020 10:16pm
Brit Plumber
I initially bled mine by popping it in to sport dynamic or whatever it's called mode and ragging it around some corners. When I bled it properly there was very little air trapped in the ARB. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #606901 Sun Nov 22 2020 11:25pm
Oldandconfused
Thoroughly enjoyed following this thread, well done and no doubt saved yourself a pile of cash Thumbs Up
Post #606905 Mon Nov 23 2020 8:51am
the_wombat
Thanks Thumbs Up
MOT booked for Wednesday, so took it for another test this evening and the ACE warning light came on and wouldn't clear on ignition cycle. I cleared it with my Hawkeye (Code U0434) but it kept coming back straight away!!
Fearing having to cancel the MOT, I have just spent an hour in the dark and solving a leak on the back ARB. Foolish me manage to nick the side of the O ring seal on the rear ARB pipe that is the most difficult to get in because you can't see it (so all done by touch). Shocked
Luckily I bought a couple of spare O rings and plastic spiral washers, and fingers crossed its back in, no leaks yet, and no warning lights at all.
MOT Wednesday!
Post #606928 Mon Nov 23 2020 8:27pm
mgrover
congrats, defo keep some spare orings. since if they go due to the high pressure nature of the system it just throws its entire guts all over the floor haha
Post #606964 Wed Nov 25 2020 10:38am
the_wombat
Thumbs Up Thumbs Up
Passed its MOT so back on the road for tomorrow!!
Post #606974 Wed Nov 25 2020 4:36pm
the_wombat
Post #606975 Wed Nov 25 2020 7:12pm
the_wombat
Been using to commute 34 miles a day for a week now.
Fingers crossed and touch wood, no leaks or other issues so far from the suspension after the work I have done.
A few other things coming to light as I use the car which I might post some pics as I work on them.
This weekend:
- Swapping the A pillar internal trims (thanks Nige) and running the power lead for the dashcam
- Repair to the centre console 12v outlet. The bezel disintegrated when I plugged a compressor into it
- Lower steering column has a bit of play so replacing that.
Post #607213 Fri Dec 04 2020 6:50pm
idi
Have you considered taking the power for the dashcam from the overhead lights unit? There's a guide for it somewhere on here.
Mine powers on when the car is unlocked with the keys or doors are open on the keyless entry, and powers off when locked again.
Post #607214 Fri Dec 04 2020 8:04pm
the_wombat
Thumbs Up That’s a dammed fine idea! I’ll search for the guide Thumbs Up
Post #607215 Fri Dec 04 2020 8:50pm
idi
This is the guide I used. It's for a 2015 RR but was the same process and same wires for my 2010.
https://dashcamtalk.com/forum/threads/hard...ort.13011/
Post #607216 Fri Dec 04 2020 9:30pm
the_wombat
Just ordered this from Amazon which should do the job and can be mounted as suggested in the interior light console.
INRIGOROUS Micro Usb Car Camera Hard Wire Kit DC 12V to 5V Power Inverter Converter Regulator Kit for Car GPS Tablet Android Phone PDA DVR Camcorder Recorder
Post #607232 Sat Dec 05 2020 3:39pm
Jimbo65
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
Ace Pipes
Looking to replace part of leaking rear pipe.Can anyone tell me ID of pipes?OD is 10 mm
Post #608653 Fri Jan 15 2021 5:19pm
Jimbo65
Rear pipes
Disco_Mikey wrote:
Less than a grand
Not a body off job
What about rear?
Post #609229 Tue Jan 26 2021 3:11pm
Disco_Mikey
Rear pipes?
What year?
Post #609237 Tue Jan 26 2021 8:29pm
Page 4 of 5 <12345>
