Home > Technical > ACE leaking |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Less than a grand
Sun Jun 28 2020 11:07am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
mine did same i changed it manually.
Sun Jun 28 2020 11:08am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
Wafoo - where did you buy the vehicle? Was it privately or from a dealer? If it's from a dealer, take it back and demand they fix it. That is your right under the law. Don't be fobbed off by the "warranty says no, mate" response. They have a legal obligation to fix it unless they told you it was leaking when you bought it. 2012 SDV6 - it's missing a couple of cylinders
Sun Jun 28 2020 11:20am |
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 |
I bought it private, FSH 12 months mot, did all my checks, bought a warranty as I've been bit before
Sun Jun 28 2020 12:57pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
Well apart from the ‘thing’ I shan’t mention, you’ll have had 2 of what I would consider the 4 main things that would go wrong on that age of car. The ACE pipes, the roll bars, the EPB and the other one which I won’t jinx. 2019 5.0 SC SVA (Current)
Sun Jun 28 2020 9:33pm |
Is there a prize if I get all four? 🏆🏆 |
Mon Jun 29 2020 8:05am |
Tbf I think the bars only go if there's a leak and not enough oil getting to them |
Mon Jun 29 2020 8:48am |
I believe there’s no seals on the outer side of the bars and like everything else that rotates, they ware out and this is accelerated by dirt and contaminates. 2019 5.0 SC SVA (Current)
Mon Jun 29 2020 10:10am |
There is a prize for all 4 but you won’t want it. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Jun 29 2020 10:11am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Kev
Mon Jun 29 2020 11:58am |
Excellent, pipes corroded through, so sod it, pipes to be changed, new valve block, seal kits booked in for Thursday, just waiting for the suspension to give up the ghost to round off the week |
Mon Jun 29 2020 4:17pm |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 160 |
New valve block ? |
Mon Jun 29 2020 5:36pm |
Garage say they have about 50% success rate fitting new pipes to the old valve body with corrosion etc, if it leaks the whole lot has to come off again, they're a Land Rover indie so I'll go with it |
Mon Jun 29 2020 6:49pm |
how much is one of those,,got to be £500 plus
Mon Jun 29 2020 7:17pm |
