Home > Technical > Blown turbo |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
Recons are not the best, I'll only fit a brand new OEM unit, as that's the only way the quality of the parts is guaranteed |
Wed Sep 30 2020 3:41am |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 80 |
Did you change the oil feed pipes, which cool the turbo, when you fitted the new ones? If you fail to let the turbos cool for a couple of minutes after a run the oil carbonises and blocks the pipes, which probably explains why the originals failed in the first place. |
Wed Sep 30 2020 9:17am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
Yeah I was going to say, you should change the oil feed pipe and return pipe.
Wed Sep 30 2020 11:01am |
Tam boy Member Since: 29 Sep 2020 Location: Derry Posts: 3 |
All the pipes were throughly cleaned and checked, garage saying that some micro chamber in the block could of blocked causing it to starve the turbo of oil , ever heard of this ?? |
Thu Oct 01 2020 9:30pm |
The saying now to replace engine think that’s a bit extreme tbh |
Thu Oct 01 2020 9:33pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
find another garage. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Oct 02 2020 9:18am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Surely the garage you used guarentee their work? That being the case it's down to them. Unless they advised changing items which you declined. Bet they change their minds about changing the engine. |
Fri Oct 02 2020 9:57am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
It's down to the garage to sort it out. They fitted the turbos that then failed. Their problem. I'd perhaps be inclined to suggest they fit new turbos and then you'd pay the difference between the new and reconditioned item price. That would be fair and you'd end up with decent turbos with a year's warranty. 2012 SDV6 - it's missing a couple of cylinders
Fri Oct 02 2020 10:09am |
