![]() | Home > Technical > Blown turbo |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
Recons are not the best, I'll only fit a brand new OEM unit, as that's the only way the quality of the parts is guaranteed |
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
Did you change the oil feed pipes, which cool the turbo, when you fitted the new ones? If you fail to let the turbos cool for a couple of minutes after a run the oil carbonises and blocks the pipes, which probably explains why the originals failed in the first place. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Yeah I was going to say, you should change the oil feed pipe and return pipe.
Tam boy Member Since: 29 Sep 2020 Location: Derry Posts: 3 ![]() ![]() ![]() |
All the pipes were throughly cleaned and checked, garage saying that some micro chamber in the block could of blocked causing it to starve the turbo of oil , ever heard of this ?? |
The saying now to replace engine think that’s a bit extreme tbh |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Surely the garage you used guarentee their work? That being the case it's down to them. Unless they advised changing items which you declined. Bet they change their minds about changing the engine. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
It's down to the garage to sort it out. They fitted the turbos that then failed. Their problem. I'd perhaps be inclined to suggest they fit new turbos and then you'd pay the difference between the new and reconditioned item price. That would be fair and you'd end up with decent turbos with a year's warranty. 2012 SDV6 - it's missing a couple of cylinders
