Home > General > Spare Key?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Spare Key?
2006 Sport. Is it possible to have a spare key cut without going back to Land Rover? It wouldn't necessarily have to perform all the functions, just open the door via the door handle and start the ignition. Andrew Kennedy
Post #604817 Wed Sep 23 2020 5:13pm
you can take a photo of the key blade, and then use keys in the post off ebay, who will send you a metal cut blade.
This however will not start the car. You also need the case and electronics. If you have an IID this can programme keys or people are trying an actal which is around £50
Post #604852 Thu Sep 24 2020 11:56am
andrew kennedy
Thanks Andy!! Andrew Kennedy
Post #604865 Thu Sep 24 2020 3:48pm
https://www.disco3.co.uk/forum/key-fob-pro...90764.html
IID is better if you can afford it
Post #604869 Thu Sep 24 2020 5:46pm
Stevepd
I used them for create a second key and programmed it myself with the IID tool. Key worked fine although it required a squirt of WD40 and its been fine since. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #604889 Fri Sep 25 2020 7:26am
Would not advise WD40 in ignition barrel/key, use a Graphite Powder if it is sticky, as the WD40 will gum it up over time.
Post #604890 Fri Sep 25 2020 7:46am
