![]() | Home > Wheels & Tyres > 275/40/R20 change |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
Hi all i'm currently running 275/40/R20s i've read going to 275/45/r20s there is no issues with rubbing etc, could i go for 275/50/R20s or would this cause rubbing on full lock? |
Drewlr4 Member Since: 05 Aug 2020 Location: South Devon Posts: 55 ![]() ![]() |
Im running 255 55 20 with no issues if that helps, which i believe is the correct tyre for 20's |
Yes looking for a bit more side wall, and all 4 corners will need to be changed soon just lookin at my options. |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
On the L320 the OE 20 inch rims running the factory fit 275/40s are 9.5J. On the L494 the OE 20 inchers run 255/50 and are 8.5J I believe. p.s. IIRC the offsets are et53 and et47 respectively 2010 TDV8 - current - my first RRS, loving it so far...... 2005 Cayenne S - handling defied physics and what a sound, so sod the mpg! 1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim Lots of other non 4X4's in between times......... |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I have been running 275/45 x 21" wheels and tyres from a L494 on a L320 for 5 years and had no issues or rubbing in any way, even lowered the suspension slightly. The overall diameter of the 275/45 x 21" is approx. 781mm on a 275/50 x 20" it is 783mm so you should not be a problem with dia. although there is a 4mm offset difference between the 21" rim for the L494 and 20" rim for the L320 don't think should be a problem as the tyre width on the L320 is 275 on a 20" rim anyway. Cheers Col |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 ![]() ![]() ![]() |
Seatown is right 275 is 9.5 and 255 is 8.5, currently going through this myself. |
Tubby-1 Member Since: 17 Mar 2019 Location: isle of wight Posts: 5 ![]() ![]() |
check with an online tyre calculator as to what will happen with different profiles as mine is running 255 55 20 and is doing 76 mph with speedo showing 70mph, checked with garage and they cant adjust the speedo with the iid tool as the profile is wrong for my motor https://www.tyresizecalculator.com/tyre-wh...calculator |
tsinc80697 Member Since: 10 Aug 2020 Location: Manchester Posts: 57 ![]() ![]() ![]() |
You can see the difference between wheel and/or tyre sizes here - https://www.willtheyfit.com/
