Home > Wheels & Tyres > 275/40/R20 change
1richard1
275/40/R20 change
Hi all i'm currently running 275/40/R20s i've read going to 275/45/r20s there is no issues with rubbing etc, could i go for 275/50/R20s or would this cause rubbing on full lock?
Post #603923 Sun Aug 30 2020 8:31am
Drewlr4
Im running 255 55 20 with no issues if that helps, which i believe is the correct tyre for 20's
Post #603955 Mon Aug 31 2020 9:54am
Tyrefitter
I’m sure the rims with running 275 are wider than the 255 when the vehicle was new.If you have 275’s on now your best bet is 45’s as they are more comfortable than the 40’s. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #603956 Mon Aug 31 2020 10:04am
1richard1
Yes looking for a bit more side wall, and all 4 corners will need to be changed soon just lookin at my options.
Post #603961 Mon Aug 31 2020 12:31pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
On the L320 the OE 20 inch rims running the factory fit 275/40s are 9.5J. On the L494 the OE 20 inchers run 255/50 and are 8.5J I believe.
p.s. IIRC the offsets are et53 and et47 respectively 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #603966 Mon Aug 31 2020 4:24pm
Re: 275/40/R20 change
I have been running 275/45 x 21" wheels and tyres from a L494 on a L320 for 5 years and had no issues or rubbing in any way, even lowered the suspension slightly. The overall diameter of the 275/45 x 21" is approx. 781mm on a 275/50 x 20" it is 783mm so you should not be a problem with dia. although there is a 4mm offset difference between the 21" rim for the L494 and 20" rim for the L320 don't think should be a problem as the tyre width on the L320 is 275 on a 20" rim anyway.
Post #603974 Mon Aug 31 2020 10:59pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Seatown is right 275 is 9.5 and 255 is 8.5, currently going through this myself.
Post #604082 Thu Sep 03 2020 7:57am
Tubby-1
check with an online tyre calculator as to what will happen with different profiles as mine is running 255 55 20 and is doing 76 mph with speedo showing 70mph, checked with garage and they cant adjust the speedo with the iid tool as the profile is wrong for my motor https://www.tyresizecalculator.com/tyre-wh...calculator
Post #604365 Wed Sep 09 2020 11:54am
tsinc80697
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Firenze Red
You can see the difference between wheel and/or tyre sizes here - https://www.willtheyfit.com/
Found it the easiest site to use and have used it for years!
Post #604459 Fri Sep 11 2020 3:19pm
