Home > General (L494) > Access mode
Rainboy
Scotland 2005 Range Rover Sport Supercharged Santorini Black
Access mode
Hi guys, just been reading an old post regarding access mode and the suspension rising when pressing access mode, possible compressor fault or blocked filter on the compressor exhaust , my question is can I remove this filter to check or replace without codes appearing and suspension issues, 2014 sport,thanks 👍🏻
Post #602748 Tue Aug 04 2020 8:04pm
scarey
you can remove the brass filter or better still drill a hole through the centre...
Post #602798 Wed Aug 05 2020 1:38pm
Rainboy
Thanks, I’ve just ordered a new one that should be here tomorrow, hopefully that sorts out my problem 👍🏻
Post #602806 Wed Aug 05 2020 2:35pm
crasher73
I've the same problem. Would you mind letting me know if the replacement part solves the issue before I decide whether to drill a hole? Thanks
Post #602837 Thu Aug 06 2020 7:48am
Rainboy
No problem👍🏻
Post #602861 Thu Aug 06 2020 12:20pm
Rainboy
Access mode
Crasher 73,picked up the new exhaust block today,£10😀,the Indy dealer guaranteed me that I was wasting my time but how wrong was he!,ten minute job and the valve was blocked,6 mm drill will sort you out ,can’t thank Scarey enough for his help, thanks again guys😂[/img]
Post #602877 Thu Aug 06 2020 6:45pm
Tyrefitter
I had same problem with a friends sport,changed filter & fixed problem & still working 12 months later,I saved his old filter & drilled a hole in it in case I get another with same problem. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #602899 Fri Aug 07 2020 4:05am
crasher73
@Rainboy. Really sorry for the delayed reply. Just occurred to me I think you're the same guy on the L494 Facebook page, we got some top advice from Ian Adam.
I just drilled a hole, worked a treat, and still working..........thankfully Laughing
Thanks again pal
Post #603284 Fri Aug 14 2020 1:04pm
Eaters
Over the years my RRS has done a similar thing. Sometimes (but not all the time) putting it into access mode produces a Suspension Fault warning and it stays where it is. I will still pump up to Off Road mode and back down to standard, no problem.
Just lately, when this fault occurs, I get the message that the car has sensed I have grounded out and puts it into super off-road mode (can't remember the exact wording) and tells me to reset the suspension once I am clear of the obstruction. Doesn't happen every time however.
Is this the same problem and solution as discussed here or should I be looking for something else? It going into my indie in September for a couple o other issues and so I can get the codes read then. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603313 Sat Aug 15 2020 7:26am
knwatkins
It could be Robin. However, I had this problem and for me it was my offside front strut preventing the vehicle from lowering to access mode.
I replaced both front struts as they were worn anyway and the fault was resolved.
The best thing to do is to monitor the 4x4 screen and the height sensor data using the IID tool to conclude the issue. This may be a bit difficult if it's intermittent though! Kev
Post #603319 Sat Aug 15 2020 10:20am
Eaters
Cheers Kev
I'll get the indie to check it over when it goes in. Robin
Gone:
MGZTT 190 2.5
Post #603322 Sat Aug 15 2020 10:43am
Kitchenfitter
What is the cost for a indy to change filter as mine does this now agaain.
When in auto mode and i open the door it lowers to acess mode then raises to either normal or off road height. Press the access button a few times and it does lower to acess height.
Im not much of a mechanic unfortunately RRS HSE DYNAMIC 2015 ODESSEY RED
Post #623266 Fri Apr 01 2022 4:16am
Eaters
I can't speak for the filter change as, in the end, I had the whole compressor replaced (£500). The indie guys showed me the old compressor and you could see the desiccant had got through the filter and was all over the place. I don't believe its a difficult job for your indie as the compressor is quite accessible. As Rainboy says, it was a 10 minute job. Best to give your indie a ring and ask. Robin
Gone:
MGZTT 190 2.5
Post #623267 Fri Apr 01 2022 6:25am
Tyrefitter
Kitchenfitter,the filter is probably around £10 noe,when I purchased one around 2.5 years ago it was £8 delivered.This is the filter & the 3rd pic is the filter after I drilled a hole through the middle,the new filters come drilled so I’m guessing LR have had problems & started fitting them with holes down the middle.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #623268 Fri Apr 01 2022 6:41am
Grimble
I'm going back many, many years to my days on the factory shop floor, but that looks to me more like an 'exhaust' rather than a filter.
Usually installed to reduce noise in a pneumatic system when air has to be released.
If you are drilling a hole in it, there's not much point having it fitted at all. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #623273 Fri Apr 01 2022 10:19am
