Home > General (L494) > Access mode |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677 |
Yes it is a exhaust,when adjusting height you can here it in the car without it,,you say if I put a hole in it why have it there at all.Then why does the new one come with a hole in it,when fitted with the hole in it you cannot here the air when adjusting the suspension so hey presto it works. Andy.
Fri Apr 01 2022 11:13am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 914 |
Andy, you lost me there
Fri Apr 01 2022 2:03pm |
What I’m saying is if you purchase a new filter for the exhaust side of the compressor they have a hole down the middle as opposed to the early models not having a hole,,so probably because of the problems with the early ones causing problems with the suspension they fitted ones with holes to eliminate the suspension issues.
Fri Apr 01 2022 3:35pm |
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 349 |
Ok you guys now created a mine field for me lol RRS HSE DYNAMIC 2015 ODESSEY RED |
Fri Apr 01 2022 7:55pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 |
There will still be some kind of silencing effect, think along the lines of a silencer on a gun. The noise will be generated by a narrow port in the valve block so the sound waves caused by the high velocity of the air exhaust will still be baffled by the exhaust but not as effectively as if the exhaust were whole.
Mon Apr 04 2022 10:47am |
