![]() | Home > General (L494) > Access mode |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 ![]() |
you can remove the brass filter or better still drill a hole through the centre... |
Rainboy Member Since: 26 Feb 2015 Location: glasgow Posts: 25 ![]() ![]() ![]() |
Thanks, I’ve just ordered a new one that should be here tomorrow, hopefully that sorts out my problem 👍🏻 |
crasher73 Member Since: 31 Jan 2020 Location: Peterborough Posts: 23 ![]() ![]() |
I've the same problem. Would you mind letting me know if the replacement part solves the issue before I decide whether to drill a hole? Thanks |
No problem👍🏻 |
Crasher 73,picked up the new exhaust block today,£10😀,the Indy dealer guaranteed me that I was wasting my time but how wrong was he!,ten minute job and the valve was blocked,6 mm drill will sort you out ,can’t thank Scarey enough for his help, thanks again guys😂[/img] |
I had same problem with a friends sport,changed filter & fixed problem & still working 12 months later,I saved his old filter & drilled a hole in it in case I get another with same problem. Andy.
@Rainboy. Really sorry for the delayed reply. Just occurred to me I think you're the same guy on the L494 Facebook page, we got some top advice from Ian Adam.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Over the years my RRS has done a similar thing. Sometimes (but not all the time) putting it into access mode produces a Suspension Fault warning and it stays where it is. I will still pump up to Off Road mode and back down to standard, no problem.
It could be Robin. However, I had this problem and for me it was my offside front strut preventing the vehicle from lowering to access mode.
Cheers Kev
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 349 ![]() ![]() |
What is the cost for a indy to change filter as mine does this now agaain.
I can't speak for the filter change as, in the end, I had the whole compressor replaced (£500). The indie guys showed me the old compressor and you could see the desiccant had got through the filter and was all over the place. I don't believe its a difficult job for your indie as the compressor is quite accessible. As Rainboy says, it was a 10 minute job. Best to give your indie a ring and ask. Robin
Kitchenfitter,the filter is probably around £10 noe,when I purchased one around 2.5 years ago it was £8 delivered.This is the filter & the 3rd pic is the filter after I drilled a hole through the middle,the new filters come drilled so I’m guessing LR have had problems & started fitting them with holes down the middle.
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
I'm going back many, many years to my days on the factory shop floor, but that looks to me more like an 'exhaust' rather than a filter.
