Home > Technical > Valve cover gasket replacement caused misfire
mgrover
So... I changed the valve cover gasket of the right side of the engine. I put everything back together and the entire engine is misfiring. If I rev it slightly it stalls when it hits idle again. Plot twist, lpg works fine.
So only petrol related thing I messed with is am guessing some high pressure fuel sensor? I had to unplug it. I replugged it before I started the car, also if I unplug it and run the car it's the same issue so could the wires been Censored ? It's the sensor next to the high pressure schrader valve.
Or possible issues, only the bank I swapped that's misfiring which would indicate the valve cover gasket is letting mad air in. But no lean codes at all and the trims seem stable. But still doesn't explain why lpg runs fine.
Maybe there's also some vacuum issue? But I doubt it otherwise lean codes would be occurring
Also maybe oil is leaking to the coils and Censored up the ignition? I doubt it though cause both cylinders misfire
Post #601991 Mon Jul 20 2020 10:29pm
mgrover
Checked all the plugs just now, no oil on any of them
Post #602001 Tue Jul 21 2020 9:36am
All I can say is measure and check the plug gaps. There is probably a compromise setting between petrol and lpg (so prob not factory setting)
Then check over your work.
See if fault code indicates a cylinder with issue
Post #602002 Tue Jul 21 2020 9:38am
mgrover
Just did quick compression test, 150psi across the board for that bank. Just to check the passenger side bank, that's bank 2 right?
Also from my manhandling of the oil dipstick, its very loose. Could that be causing the vacuum leak? The whole thing is moving back and forth.
Also I remember in some post Andy you mentioned plug gaps that were better for cold starts for this engine?
Also seems to be misfiring on cylinders that I haven't touched so the dipstick seems to be the culprit
Post #602006 Tue Jul 21 2020 9:58am
mgrover
My short term fuel trim at idle in Park is 47%. There's defo a vacuum leak somewhere, and I've just got a lean code
Post #602008 Tue Jul 21 2020 11:18am
Plug you dip stick hole with a cork then and see if it sorts it.
Otherwise cam cover breathers
Post #602013 Tue Jul 21 2020 2:00pm
mgrover
I mean I've screwed the actual tube :p ama run smoke test tomorrow. Be definitive.
Also anyone who buys valve cover gaskets don't buy brit part. Doesn't fit amazingly well
Post #602014 Tue Jul 21 2020 2:59pm
mgrover
Update
https://www.rrsport.co.uk/forum/post602116.html#602116
So not brit parts fault at all my bad.
Post #602117 Fri Jul 24 2020 2:02pm
