![]() | Home > General > This car is getting expensive already |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 ![]() ![]() ![]() |
At least its getting expensive with things you want instead of having to shell out on the nasty stuff |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
Amen to that...
The problem is that the cost of repairs is why they don't get repaired but rather sold on instead.
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 ![]() ![]() ![]() |
Decided now the rear monitors will also have iptv and a ps4 on
Did you buy with the complete headrests or just the screens?
I bought the whole set, you have to fit the screens in the headrest yourself but they are already cut with the brackets installed. It's just a case of setting the width of the posts and feeding a cable down each post. I mounted the control box under the passenger seat and fed the wires under the centre console and tucked them under the carpet. Still got the hdmi and USB extension harness to do then dress the cables today, but tested it yesterday evening and had my iptv on it. I've only put that on cause its a bit different. All in all a very easy job to do but I did already have a supply there for the old cheap system
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 ![]() ![]() ![]() |
I had dreams of that but my beast is on the other side of the fence and decides its more fun breaking down every week.... 😭 |
