Home > General > This car is getting expensive already |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 169 |
At least its getting expensive with things you want instead of having to shell out on the nasty stuff L494 3.0L SDV6 Autobiography in Chile Red (Current)
Fri Jun 19 2020 9:20am |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Amen to that...
Fri Jun 19 2020 11:18am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
The problem is that the cost of repairs is why they don't get repaired but rather sold on instead.
Fri Jun 19 2020 12:14pm |
Phil2k Member Since: 18 Jun 2020 Location: Anglesey Posts: 75 |
Decided now the rear monitors will also have iptv and a ps4 on
Sat Jun 20 2020 4:27pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Did you buy with the complete headrests or just the screens?
Sat Jun 20 2020 10:23pm |
I bought the whole set, you have to fit the screens in the headrest yourself but they are already cut with the brackets installed. It's just a case of setting the width of the posts and feeding a cable down each post. I mounted the control box under the passenger seat and fed the wires under the centre console and tucked them under the carpet. Still got the hdmi and USB extension harness to do then dress the cables today, but tested it yesterday evening and had my iptv on it. I've only put that on cause its a bit different. All in all a very easy job to do but I did already have a supply there for the old cheap system
Sun Jun 21 2020 8:12am |
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 |
I had dreams of that but my beast is on the other side of the fence and decides its more fun breaking down every week.... 😭 |
Sun Jun 28 2020 3:12pm |
