Home > In Car Electronics > New Android 9 Discovery/RRS Android Stereo System |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
That's a shame! I wonder if it was when you reversed the ribbon cable, or if one of those solder bodges, ahem, bridges, caused a problem?
Thu Jun 04 2020 2:59pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
I believe it stopped yesterday, so was before i reversed the LCD ribbon ( which wouldn't do that any way )
Thu Jun 04 2020 5:23pm |
Did the Disco 4 screen work when you fitted in the sport? How long did you leave it? When I put a disco 4 screen in my car, it shuts down after about 3 minutes and won’t fire up again until it’s disconnected and the car goes to sleep.
Thu Jun 04 2020 8:15pm |
i had it connected for a few mins and it seemed fine . Since then it had been in and out quite a few times with the android unit showing some signs of life with it . the last couple of trys it was dead without any sign of life from the unit ... so i put it all back together to test and nothing
Fri Jun 05 2020 5:33am |
Had a reply from the seller , stating it was fully tested.
Fri Jun 05 2020 7:33am |
I’ll see what I’ve got as I have a few screens and I’m sure I have a 2012/13 screen for a Disco 4 which you can have to try. My only niggling feeling is the issue I had and I can’t remember exactly but I found that the FCDIM (screen) holds an abridged version of the CCF for the AV system. On power up it compares its vehicle type code to the BCM and if doesn’t match it doesn’t bring the screen up. After I fitted a special gizmo to the FCDIM to convert the type code from L319to L320, I think I remember only 1/2 a screen working which I’m convinced was because of the BCM CCF being set to dual view and then it shut down after 3 minutes or so. It does sound like a similar issue and you maybe better off with a RRS screen and turning off the DV in the CCF. 2019 5.0 SC SVA (Current)
Fri Jun 05 2020 8:07am |
Thank you .
Fri Jun 05 2020 9:26am |
If you still have the trim, try seeing how it would fit to the dash. It does look like it would fit but the Disco 4 and Sport dash trim is different which leads me to believe there should be 2 separate adapters, one for each car. 2019 5.0 SC SVA (Current)
Fri Jun 05 2020 9:59am |
Just been back through some records for a better idea of what happened with my install. When I fit the Disco 4 screen, I got lines on 1/2 the screen until I fitted the magic box. At this point I got the screen working but it shut down after 3 minutes. An ex LR software engineer suspected it was because I had the CCF set to DV and the Disco 4 never had it despite the maintenance manual suggesting it was an option. 2019 5.0 SC SVA (Current)
Fri Jun 05 2020 10:06am |
Thanks that kind of makes sense . I do have SDD so maybe i can turn it off that way . But i believe i should atleast be able to see something on the screen ? ( as i did originally)
Fri Jun 05 2020 10:30am |
Looks like support has stepped in
Mon Jun 08 2020 8:57am |
Ok new "Non" dual view RR screen came today .
Fri Jun 12 2020 2:15pm |
Dual View is also smaller and the plastic trim surround is different (although it won’t matter for what you’re doing).
Fri Jun 12 2020 2:30pm |
Ok so the support from this supplier has been good
Sat Jun 13 2020 11:11am |
