Home > General (L494) > Air con help?
therealchrisgm
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Alaska White
Air con help?
I have a 2016 RRS Autobviography. I’m currently getting cold air on the passenger side but not from driver or rear seat vents? Anyone encountered this problem and solution? 2016 RRS Autobiography Fuji White with full blackout - first RRS owned.
Post #599952 Tue Jun 09 2020 2:28pm
geoffsnook
Had it on a megane once it needed gas not enough in the system to cool it properly Thumbs Up
Post #599998 Wed Jun 10 2020 11:09am
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
I had exactly the same on my previous 2016 RRS. Needed to be re-gased. Then ended up with a damaged condenser but I think that was after the re-gas as there was 1/3 gas in it when it went for re-gas. Two months later when it failed, it had none in it. 2018 SVR
Post #600023 Wed Jun 10 2020 8:06pm
therealchrisgm
Thanks for the heads up - luckily there were no leaks and it just needed a regas. Was at 70/800 level. Said normally in RRS when they go below 80 in the gas they will only supply cold air to one side. Cost £125, luckily as mine is only 4 weeks old (used 4yo) they said they’d give me the money. Which is great. 2016 RRS Autobiography Fuji White with full blackout - first RRS owned.
Post #600091 Thu Jun 11 2020 3:58pm
the_big_1
Just like mine was. I was lucky I got mine with a year warranty. First re-gas dealer paid for. New condenser and re-gas was about £750, warranty paid in full 2018 SVR
Post #600096 Thu Jun 11 2020 6:32pm
glenn9999
i have just been told by a main dealer that they should never need to be recharged as they are a sealed unit
Post #600376 Wed Jun 17 2020 1:18pm
syl
They’re all sealed units, yet Halfords, KwikFit et al all seem to do enough re-gassing to pay for a machine. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #600391 Wed Jun 17 2020 5:08pm
therealchrisgm
Mines now gone back to not being cold? Despite only being regassed 4 weeks ago!? Anyone any thoughts? I do have an independent warranty so hoping it’s covered? I’m based in Wirral, should I take it to a local independent or a specialist? 2016 RRS Autobiography Fuji White with full blackout - first RRS owned.
Post #601306 Sun Jul 05 2020 8:52am
therealchrisgm
The weirdest thing is when I do the air con through the front seats on cold temp, it’s pumping through air con cold. So how can that be? 2016 RRS Autobiography Fuji White with full blackout - first RRS owned.
Post #601330 Sun Jul 05 2020 2:45pm
