![]() | Home > General (L494) > Air con help? |
Had it on a megane once it needed gas not enough in the system to cool it properly |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
I had exactly the same on my previous 2016 RRS. Needed to be re-gased. Then ended up with a damaged condenser but I think that was after the re-gas as there was 1/3 gas in it when it went for re-gas. Two months later when it failed, it had none in it. 2018 SVR |
therealchrisgm Member Since: 06 May 2020 Location: liverpool Posts: 21 ![]() ![]() ![]() |
Thanks for the heads up - luckily there were no leaks and it just needed a regas. Was at 70/800 level. Said normally in RRS when they go below 80 in the gas they will only supply cold air to one side. Cost £125, luckily as mine is only 4 weeks old (used 4yo) they said they’d give me the money. Which is great. 2016 RRS Autobiography Fuji White with full blackout - first RRS owned. |
Just like mine was. I was lucky I got mine with a year warranty. First re-gas dealer paid for. New condenser and re-gas was about £750, warranty paid in full 2018 SVR |
glenn9999 Member Since: 31 Aug 2019 Location: Essex Posts: 58 ![]() ![]() |
i have just been told by a main dealer that they should never need to be recharged as they are a sealed unit |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
They’re all sealed units, yet Halfords, KwikFit et al all seem to do enough re-gassing to pay for a machine. RRS MY17 SDV6 AB
Mines now gone back to not being cold? Despite only being regassed 4 weeks ago!? Anyone any thoughts? I do have an independent warranty so hoping it’s covered? I’m based in Wirral, should I take it to a local independent or a specialist? 2016 RRS Autobiography Fuji White with full blackout - first RRS owned. |
The weirdest thing is when I do the air con through the front seats on cold temp, it’s pumping through air con cold. So how can that be? 2016 RRS Autobiography Fuji White with full blackout - first RRS owned. |
